Weird ABS Codes
Old 12-09-2006, 04:39 PM
mrtomcat
mrtomcat's Avatar
Default Weird ABS Codes
When I was at the track a few weeks back running the 28" inch Dr's my ABS/BRAKE/SLIP/TCS lights came on, I figured it was because the tire diameters are off between the front and rear and after putting on the street tires it'll go away.
Yesterday I finally got my car back from getting the broken axles replaced (see seperate drag racing thread) but the lights were still on.
Performance Nissan replaced my battery because it kept on throwing these codes but the codes are still there.
I brought the car to GTM and Sam read the codes and reset it but no go.
I'm going to bring the car back to him next week to figure this out but was hoping maybe someone here had the same experience and make the research a bit easier.
It's throwing codes like ABS solenoid is not receiving correct voltage (the actual message is similar to this I don't remember it...) and
[C1127]Battery Voltage abnormal (16) and [C1109]Controller Failure (39)
I think there's a [C1110] as well.
It's driving fine but this is obviously worrysome because it involves the brake system.
Any Ideas anyone? (I swear my car is cursed)
Old 12-09-2006, 04:51 PM
Mike Wazowski
Mike Wazowski's Avatar
Did you check your speed sensors? I had the same thing, my right front speed sensor was unplugged and I kept throwing that code. I would reset it and about 1 mile later it would come back on.
Old 12-09-2006, 04:59 PM
lemansz20
lemansz20's Avatar
I have the same lights on, except the brake one. The brake one has its days when it wants to be on. If you figure out what this problem is PLZ PLZ post what you did to fix it.
Old 12-09-2006, 05:04 PM
mrtomcat
mrtomcat's Avatar
wanted to add that a buddy of mine and I had to change a wheel stud at the track (rear wheel)(first time either of us did that) could it be that we screwed something up when putting it back together is there a maybe some kind of brake alignment that needs to be done? Since we had to turn the wheel part where the stud goes in in order to fit it in and that is now off?
Old 12-09-2006, 05:09 PM
mrtomcat
mrtomcat's Avatar
since they just replaced the axles I'm sure it's plugged in, but in any case where is it so that I can check for it?
Old 12-09-2006, 05:20 PM
Mike Wazowski
wheel hub/rotor
Old 12-10-2006, 01:17 AM
mrtomcat
mrtomcat's Avatar
I drove around with the race logics graph up and it reads all 4 sensors just fine, so I don't think it's a problem with the sensors.
Old 12-10-2006, 04:33 AM
overZealous1
overZealous1's Avatar
all fluid levels are good?
Old 12-10-2006, 09:15 AM
Alberto
Cranky FI Owner
Alberto's Avatar
Anything to do with your line locks?
Ladrillo (12-30-2022)
Old 12-10-2006, 01:03 PM
mrtomcat
mrtomcat's Avatar
fluid levels are fine.
line locks work fine...i had them for 1 1/2 years and never got a code. they are also behind the abs so that they don't throw codes
Old 12-13-2006, 01:51 AM
mrtomcat
mrtomcat's Avatar
anyone have any ideas?
Old 02-09-2015, 06:34 PM
NISMO1187
NISMO1187's Avatar
i have the same problem,i was driving normally yesterday, in the "rain" and out of know where my brake, abs, tcs, and slip turned on, i checked my fluid, its at max, checked all my fuses all were good, the code was c1127 rr rh out abs sol, so i tried changing abs sensors in rear, lights still come on, lights on come on after i start it and start driving. need help cant figure out, someone must have had same problem and fixed it...
Old 05-07-2017, 03:38 PM
dfresh89
dfresh89's Avatar
Did u ever figure this out ?
aarrgghh
05-01-2022 11:04 AM
Uriyo_
09-08-2021 08:46 AM
11-09-2020 10:27 AM
kyin
10-15-2015 05:54 AM
Detailed Image
Cleaning & Detailing
09-28-2015 03:03 AM
Quick Reply: Weird ABS Codes
