anyone know how difficult, if even possible, it is to convert this to de?
^^^ not sure what is meant by this. if by this link posted, you mean that it's directly compatible then why not just say it? i'd, preferably, like to get something new. any help with this is greatly appreciated!
If you know anything about the differences between the HR and DE engines, you'd know that there's very little the two engines have in common. To think that this kit is "directly compatible" is only wishful thinking.
ok, thanks dkmura! this is a no-go for me...
Price drop
5500obo bump!
Good winter build bump! Get ahead of the spring rush a kit this cheap won’t be around for the spring for a HR.
All PM’s replied Bump.
Curious as to how well the C38-92 fits!!! It was said that the C38-91 was a tight fit with the new engine mounts.
Also what pulley size do you recommend? Could most likely order it through rotrex. 80,85 or 90 mm maybe. |
https://cimg6.ibsrv.net/gimg/my350z....6530f5709.jpegHere’s what the difference is. The inlet is wider and a lil longer. Doesn’t affect fit. I wouldn’t go with a small pulley. My buddy said he used the smallest pulley from the titan kit. I think it was under 90mm it over spun his SC and destroyed it. You can call Jackson Racing to find out. GTM/Gamma might know.
Gamma is out of business last I heard. Dimension "D" is what worries me.
What is your best price without injectors? Where are you located? |
D is only bigger cause of the inlet where the IC piping comes in by a hair ball. Rest of the charger is same size as a 91. You might have to shave a IC pipe down but I high doubt it cause there is usually a gap in the coupler.
If Gamma is out of business that makes me happy. But this is hands down the best SC kit. I’ve seen it in person and what it does to VQ motors.
I’m located in Denver. Replied pm.
It would be the best kit if their reputation was spot on, but it is not! People are basically on their own with their kits. There is no support. Did they at least give you the 120+ page install manual?
Never answered where you are located & what your best price is without injectors. |
They’ve built the best kit but yeah them as a seller are crooks. I pm’d you the price.
Instructions are online just gotta search for it.
All pm’s replied great winter build Bump!
