FS: Vortech V7 Ysi Supercharger Kit
Up forsale is my Vortech V7 ysi Supercharger Kit.
Bought is used from Meanz in 2016 (you can check his build thread for all the info). There is about 1100 miles on this charger.
On my last post I had stated 423rwhp and 328 torque, which was incorrect as those were the numbers for my V3sci supercharger. This kit was at 458 rwhp and 379 torque which was dropping boost when it was getting tuned. This charger is capable of way more power as other’s have had success with it.
The charge pipe maf bung has been closed off since I do not need a Maf sensor (using AEM Infinity).
The kit will be come with all piping (sandblasted and powercoated), blower, clamps, bolts, bracket, and pulleys (2.75, 2.87, 3.12, 3.33).
The kit comes with a Treadstone TR1245 Intercooler which is welded onto the crash bar.
I also suggest getting some Gates green HD belts.
The intake was custom fitted and sits nicely behind my bumper.
Using this set up will also mean not running AC, unless you do some modifying. Running aftermarket radiators will be a tight fit.
Running a fluid damper or ati will help make more power.
This kit does not come with Fuel pumps, Injectors, or Tune, you will have to get those items yourself.
I have never raced, tracked, or abused my Z.
$4000usd shipped + pay pal fees DM if your interested.
Located in Winnipeg Manitoba Canada.
Thanks!!
Thanks!!
Conway_160 (10-13-2017)
BluestreamDE (02-07-2018)
