Oil pan Spacer and Oil Qty ?
on
Hello guys, i´m finishing my twin turbo setup, but I noticed that with the oil pan spacer the oil dip stick won´t read oil and if I add more oil level will be above the turbos return line and obstruct the oil flow.
So my question is, should I get a larger oil dip stick? any ideas wich one will fit?
Thanks!
Thanks!
General & Tech Moderator
I tried to copy/paste the formula to calculate the area of a trapezoid (2 dimensional oil pan). If you don't mind a little math, measure the pan spacer dimensions and multiply by thickness ( 3 dimensional volume ), then convert to ml or quarts. This should get you pretty close.
Also, the quantity might be on mfgr website or spec sheet, gl!
Mine had a spacer on the pickup (AAM). I'd think most do, I'd make sure you have one. That said, I found I had to drop below the H mark on the stick to get rid of the occasional minor smoke. I now set it close to the L mark. My volume is about .75 of a litre up, but it's hard to tell due to the oil cooler lines, etc.
amolaver
12-21-2004 07:02 AM
