Sleeves or no sleeves?
Old Jan 25, 2025 | 08:24 AM
RodiZio's Avatar
RodiZio
Default Sleeves or no sleeves?
Hey Y'all, I'm going to be rebuilding my de motor and considering going with Darton mid sleeves. I plan on making 700+ hp with turbos, cams, etc., and E85. Should I sleeve the block or not?
Old Jan 25, 2025 | 07:31 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Amother 700+ HP build thread being moved to a more appropriate forum. Maybe you'll get some knowledgeable opinions if you post what your current budget is, and what kind of mechanical skills you bring to the party.
Old Jan 26, 2025 | 10:54 AM
Conway_160's Avatar
Conway_160
I'm not sure anyone has had a positive experience with sleeves on a DE. You may want to look at CSS block guards. If your feeling supper spicy you could do what some of the Honda Boys do and put that sealant **** in to make a semi closed block.
Old Jan 27, 2025 | 12:30 PM
bealljk's Avatar
bealljk
As mentioned above - what is your budget for this build?
Tell us about your turbo system that you have (or youre going to build)?
What fuel setup do you have(or are you planning on)?
What clutch / flywheel setup do you have (or are you planning on)?
Have you upgraded your radiator? Oil Cooler?
SubsetZ1023
Jul 17, 2019 06:12 PM
260DET
Jun 21, 2019 06:57 PM
bigbri
Jan 25, 2007 01:07 PM
jcarp
Mar 24, 2006 07:03 AM
