MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Forced Induction (https://my350z.com/forum/forced-induction-182/)
-   -   BOV's on the ATI (https://my350z.com/forum/forced-induction/76960-bovs-on-the-ati.html)
was wesman May 28, 2004 07:41 PM
BOV's on the ATI
Who has replaced their stock ATI valve with a louder aftermarket BOV ?
If you have, what did you use and what are your impressions ?
--wes
Enron Exec May 29, 2004 07:05 PM
I think at least 2 members on this board with the ATI have used this BOV to some success: http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Do a search for daking350 or turboxs and i think you might find the install someone posted. You also need something to plug the other end of the IC piping that was originally connected to the ATI surge valve. I think its some sort of rubber disk that can be inserted into a pipe and then you tighten the screw in the center and it expands to make a air tight seal.
was wesman May 29, 2004 07:24 PM
Cool...I'll check those links out.
I know the rubber disk you're talking about....i used a couple of those from Home Depot when i plugged the stock recirculation valves on my 300tt after I swapped to the Blitz BOV's
Thanks man.
--wes
Enron Exec May 29, 2004 08:09 PM
Ahh I found that post, but it was form another 350Z forum. It has the complete write up of the install/swap. http://**********.com/forums/tutorial...&CODE=02&id=13
I might do this mod too since alot of ppl say the stock ATI surge valve is weak.
