2006 G35C Tow Hook Thread Size
Anyone know what size threading the 06 coupe takes?
It's either 22mm or 24mm. My car is parked 1/4 mile away and I'm too lazy to go check. If anyone with an 06 coupe has purchased a Stillen plate bracket, can you please advise me as to what size to order? |
http://www.stillen.com/product_files...e_Brackets.pdf
According to Stillen's site, the 06 Coupe uses 24mm (then again, it says "potential fitment"). However, a friend measured his tow hook threading and it came out to be 7/8" (22.2mm). Can anyone who actually purchased this kit for an 06 Coupe verify what size I need to order? |
Anyone?
measure it. its the only way to know for sure.
Cal, I just double checked using Stillen's template. Both the OEM tow hook and the Stillen bracket I have fit the 24mm hole.
awesome! thanks a bunch kurtis! I wonder why nissan decided to use three different sizes for the g while the z only has two sizes.
btw, where did you find that template? i've seen it before, but I wasn't able to find it on the stillen website. anyway, thanks again, kurtis! |
the size is 1' x fukcalvin"
