Broken Bolt in plenium
on
Ok well as the title says, I some how snapped one bolt while installing the plenium spacer. It was one of the bolts that connect the lower plenium. Pretty much holds that metal piece in place. So I sent mail to Motordyne but they haven't replied in days, so I was wondering, would it be dangerous to drive the car? the other 5 bolts are down tight. I plan on replacing this bolt but was just wondering the situation I got myself into, and if it is bad.
on
sorry i don't have an answer for you, but out of curiousity, were you using a tourqe wrench? i'm getting ready to install a plenum spacer, and wanted to make sure that i am aware of everything before i get half the engine taken apart... i'll be using a tourqe wrench, but if you were and it still snapped....i'm scurred... :S
on
hahah you guys knew exactly what I did wrong. I was reading it and it said 15, so I went just alittle harder then bam, broken bolt.
The install is pretty easy, it was totally my fault. It started raining as I was putting things back together and got sloppy. But I would rate the install on the same level as installing a CAI.
Question regarding the bolt tho. Will it rust? or is it exactly like the one that is being used.
on
I had the same problem when installing my spacer.. I just took a drill and a bit smaller than the broken piece and drilled into it, after that I put the drill in reverse and it came right out...
on
I can't seem to find this bolt, I tried the part number but came up with nothing. Anyone know the size of the bolt and such, and where I can buy a replacement.
on
on
I think you are talking about a different bolt. The bolt that I am refering to is on the inside of the plenium. It holds the gasket down, which is attached to a bronze plate. There are 6 bolts and I broke 1 of those bolts.
the price for the bolt is 1.1$, call Performance Nissan ask for Andy or Tony just tell them to direct you to Nismo Team, they helped me with my problem.
P.S. i`m so sure about the part number.
on
Thanks for the help both of you. I just called and ordered 4 bolts in case anything like that ever happens. I can finally finish the install and start on my sway bars =).
