Need help with Fujita Installation Please!
So I am installing my intakes and the sensor that is right by the top of the intake its a round circle,. Well the pipe is not lining up at all, and it ripped my pipe the rubber one that comes with the fujita, My question is can I use a long pipe and just wrap it around or something? thank you, oh yeah and should I bolt on the intakes but it seems that it is very stiff already, or should I just attach it for extra safety? thank you
the rubber hose that you ripped, the one that was suppose to connect to the rubber host coming from teh block (underneath the intake) is important. it was suppose to stretch over the cars tubing. Cracked or put on their makeshift will cause an air leak/your car running like chit.
Bolt the intake onto the engine or the intake will move around when you accelerate. There are several aluminum A/C lines directly underneath your intake that are quite expensive to replace if broken. Bolt it up, be safe. Hope that helps, you can probably pick up that tube that came with it at a hardware store.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
