Nismo R-Tune headers and many other question.
Old May 4, 2009 | 10:52 AM
ICE350z's Avatar
ICE350z
Default Nismo R-Tune headers and many other question.
Ok I just ordered my nismo CAI, exhaust, and R-tune headers at mynismo.com. My question is, does anyone here have the R-tune headers installed on their Z?? And if so, do you have trouble passing the state inspection with it?? I did my research on it before putting in my orders, I went to the dealership and talked to their mechanic and he said I shouldnt have trouble passing the state inspection with the R-Tune headers. Then I went to my local tuner shop and asked the same question, but this time the mechanic said I wouldnt pass the state inspection because its an R-tune and its meant for the track only. I dont know which one to believe. Ok and heres the rest of my questions. With the Nismo CAI, exhaust and headers, am I going to need an ECU reflash or reset?? My best friend has the same set up on his 03 Z and when he got the parts installed his check engine lights came on and he had to get an ECU reset to solve the problem. I was told that the VQ engine is very sensitive when it comes to engine modifications. Would it be smarter just to go ahead and order a UTEC or an ECU reset/reflash??
Old May 4, 2009 | 12:58 PM
How about taking a deep breath. Let it out slow. Relaxed?
Install the stuff that you have. THe car will run fine. We will solve any trivial details later If necessary.
Note: Just curious why you are spending $2,500 on intake and exhaust and maintaining the OEM catalytic converters?
Old May 4, 2009 | 01:11 PM
luv2bsidewaz's Avatar
luv2bsidewaz
I'm running intake, plenum spacer, lower collector, test pipes with cel fixers and exhaust and haven't had an engine light problem at all. A reflash/reprogram isn't necessary but would be desireable down the road to get full advantage of all of the parts you install. I think it will be just fine.
Old May 4, 2009 | 01:21 PM
QNman's Avatar
QNman
My guess would be the same reason I wouldn't put on "hi-flow" cats... because they are reported as "track use only". I would be nervous about not passing emissions. But I'm just guessing here.
Old May 4, 2009 | 01:47 PM
Chaser720's Avatar
Chaser720
Lemoned Z
Your best move would be to sell/return the headers (minimal gains for the money and a royal PITA to install) and get some test pipes instead or if you need to pass an inspection try high flow cats instead.
SC = NO smog testing (FTW)
Old May 4, 2009 | 06:34 PM
1cockyZ's Avatar
1cockyZ
Just stop. Nismo headers for the money are not the best choice. CAI also not the best by a long shot. If your in nj pm me.
Old May 4, 2009 | 07:18 PM
Supra2k's Avatar
Supra2k
wow....you must be a baller
you just spent like 3 grand lol
Old May 5, 2009 | 08:04 PM
BurntZ33's Avatar
BurntZ33
agreed. headers not the greatest, like these guys say, take that money, get hfcs and a plenum spacer and call it a night.
Old May 6, 2009 | 11:09 PM
j-velocity's Avatar
j-velocity
You won't get the most out of the headers if you don't have TP or HFCs.
Get those before you install headers.
nanotech
Oct 2, 2015 05:02 AM
