one cat on 2003 350z is red hot the other is not
on
Second time today you posted this davidv(that I saw anyway)...
OP, I'm not a physicist or anything...but thats usually indicative of something blocking it. My guess is the guts of the Cat began breaking down and are now clogging it up. The heat has no way to dissipate out of the exhaust on that side, so it superheats and glows...similar to holding a torch flame to metal to soften it up, etc.
on
red hot cat
im down with the unburnt fuel thing .its been running like crap ever sence i had this motor put in . i just got the cats off an o7 but this same motor has not run rite from the get go. what would be my next step i have replaced all 4 o2 sencers the upper harnness for plugs and fuel injects. i guess i should have got the ecu out of the car i got this motor from .thing is i be a broke ho .and im fastley running out of money.
on
It does makes sense that throwing more fuel into it from running poorly could cause it as well.
However, a clogged up cat on one side could also conversely make the engine run poorly as well.
You throwing any codes? Are you positive the injectors are running correctly and your plugs are good? etc...few things you could check now at this point since people mentioned a couple other ideas.
FromGtoZ
09-20-2015 03:41 PM
