Stillen Gen 3 VS. Injen Long Tube Intakes
#62
on
I am saying that I did not like the loss I had in the mid range only to make a few extra ponies up top. The tuner said that the Stillen intakes use smaller diameter tubing which could cause turbulence and therefore decreased power across the powerband.
#64
on
I just realized you have the Injen setup. Are the intakes 3in diameter like the stock tubing? This could be why you are seeing gains. I know that people see gains with the Stillens on stock tuned cars but I read that could be caused by the leaned out A/F ratio. I can't imagine that I am the only person that had this outcome.
#65
My tuner is R/T Tuning in Pa, very reputable and I am tuned with Osiris. I was tuned on the same dyno both times by the same guy (owner of shop/head tuner) in virtually same conditions. I don't know what I could have done wrong but all I know is after 2+ hours of tuning I lost major power in the mid-range and had only minimal gains up top. The tuners explanation was the small tubing or a misfire problem in the mid-range and being that my car only had ~20k on it at the time, the tuner dismissed that possibility. However, he did say he sees gains with the Injen setup. I am not sure of the size of that tubing but I'm guessing its bigger. I was shocked when I received my Stillens that the tubing diameter was smaller than stock but I thought I read enough reviews supporting them but apparently I was wrong.
#66
on
I dont know why some of you are so surprised....if you look elsewhere you will see that sleeperz is not the only one that has experienced little to no gains with aftermarket intakes. I would love aftermarket intakes as it usually goes hand in hand with other mods of a car but after reading countless people say its not worth it ill stick with their word.
Good point on the diameter of the tubing though. I want to see more independant dynos by people with the injens.
#67
Long tube intakes are different than "regular" aftermarket intakes for the HR 350z...The Stillens and the Injens are both dyno proven by both the companies, different companies, and plenty of forum members on here...BOTH of these SPECIFIC long tube intakes are dyno proven to make power AND torque. Not sure what the confusion is about. Maybe your tuner is doing something wrong, or maybe your z just sucks, who knows? But I made power with BOTH intakes when I had them, and others on here have as well...If you don't want the intakes, put the stock ones back on and call it a day, because someone is making power, otherwise they wouldn't be popular/sell.
#68
So yes (CTZ860), keep believing the people who aren't showing you dyno results.....hard data is a lie I guess.
(side story, kinda relates)
I had a friend with an 06 with HKS Supercharger, he got a custom intake built and put the air intake outside the engine bay like these intakes and reduced his intake temps by 20 degree's and increased performance.
#72
on
I can tell you the biggest difference between these two intakes just by looking at the pictures.
If any of you tune your own car, and own one of Greg Banish's Book engine managment advanced tuning, you will find the answer in chapter 4.
many aftermarket companies sell MAF sensors, or adapters that reduce the area of the sensor exposed to the incoming air charge. If you notice, stillen's intakes have this design. The sensor misreads the incoming air, and the engine leans out the mixture, potentially making more power.
this discrepancy can be tuned out using the MAF transfer feature in many tuning softwares such as uprev which make the stillen design redundant once you flash tune your car
at least this is what i think im my completely 100% non professional opinion lol
#73
on
EXACTLY! I had these intakes along with pulley's and light weight flywheel and made a good 23 whp over base power (Stock exhasut), so you are correct in saying that most "regular" intakes do next to nothing, but these do pull air from outside the engine bay.... there is a difference.
Send me a pair of the Injens and I will pay for the dyno.
#74
on
Injen on my SMB 350z situation
Sup homies, I got a killa deal on this Injen dual intakes for $330 shipped to me got it installed by a nissan techy for $140. Here some pics wish I took one when the bumper was off but it turned out great anyway.
#75
on
Thanks to everyone in this thread who posted some photos of your Z with the Injen, I was able to modify the bracket to make them fit on my 07 G35 sedan. I'm glad to say that I was able to get away from buying Stillen crap. hahaha
Build quality and finish is far better than Stillen ones, and they look bitching. lol I just wish Injen relocated the MAF sensor adaptors on the back of the tube so the ugly harnesses were invisible from the top. :/
All in all, I'm pretty satisfied with the set! (My 4th set of intakes. lol)
