Where to weld in Magnaflow X-pipe?
Old Dec 25, 2013 | 07:40 PM
RawrXTC's Avatar
RawrXTC
Default Where to weld in Magnaflow X-pipe?
I've searched and couldn't find an exact answer as to where the Magnaflow x-pipe should be welded on. I've read that the original resonators are junk and should just be removed when installing the x-pipe, but that would leave the exhaust a bit short wouldn't it?
If someone could maybe show me where the x-pipe should be welded on with a quick sketch on a google image of the exhaust using paint or something, I would greatly appreciate it.
Also, which x-pipe is preferred or most often used? The perforated or the nonperforated? I'm going for a deep, but not incredibly loud exhaust note. Louder than stock for sure though.
Old Dec 25, 2013 | 08:16 PM
07maximan's Avatar
07maximan
No sketch is needed....cut off nasty resonators and weld in x pipe. Easy squeeezy....
Old Dec 25, 2013 | 08:31 PM
Itzcashew's Avatar
Itzcashew
You went it to the headers. Only logical place.
Old Dec 26, 2013 | 08:42 PM
Trevor Hebert's Avatar
Trevor Hebert
If i knew how to upload a picture via iphone. I woud show you where mine is welded.
Old Dec 30, 2013 | 07:40 PM
RawrXTC's Avatar
RawrXTC
Thanks anyways Trevor. I got an idea of where to weld it. Pretty much as far up as possible before the bends I assume? I'm also assuming that since cutting the resonators off the exhaust shop will weld on extensions to make it long enough to fit the car as well.
Old Jan 1, 2014 | 08:00 PM
Trevor Hebert
They will. Atleast that's what my guy did.
Old Jan 2, 2014 | 11:16 AM
RawrXTC's Avatar
RawrXTC
The other day I worked on a Z that came into my work and it had an HKS rep with test pipes. It's extremely loud...and badass sounding.
Old Mar 12, 2014 | 05:30 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I need pics of this "mod." I'm also wondering where the shop will cut and replace with the new piping.
Thinking of getting the so-called x-pipe to try and get the exhaust note a little quieter.
Old Apr 10, 2014 | 08:28 PM
RawrXTC's Avatar
RawrXTC
Sorry, I haven't checked the forums in awhile, but I did find out where to weld the x-pipe. I also found a picture from another member for clarification.
IMG_0743.jpg?t=1285650400
I will be putting my exhaust on as soon as it gets here next week. From what I've researched, the x-pipe goes where the exhaust's resonators and h-pipe is. So that whole section gets replaced with the x-pipe. Hope this helps!
Old Apr 10, 2014 | 08:34 PM
Jmfeld02's Avatar
Jmfeld02
I actually just had this done today. I had the shop put the x-pipe where the resonators are without needing any extra pipe. So my x was right behind the H-pipe section. They then cut off the tiny h-pipe and welded the tiny hole closed (it's honestly a pathetic 1/4" sized hole. This seemed to be the easiest method to me.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
darkgt
Dec 9, 2015 02:04 PM
hardkicks
Sep 20, 2015 12:28 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
