Traded RT Cats for Ultimate Cats!
on
I got rid of the rasp sound for good! Much better sounding all the way through the rpm range. A little more restrictive so I may of lost high rpm hp but I can still chirp in 3rd gear. It's worth the very slight hp loss (if any) for the much improved sound. If you're sick of the crappy sound you're getting from the RTs then consider switching. Thanks Adam at Z1 Perfomance!
Now the problem!! I picked up my car from my dealer on Friday night and drove it home on the highway for an hour or so, enjoying my new, more mature sounding exhaust. When I came into town and noticed a strange new vibration coming from somewhere underneath the engine compartment. I could feel the vibration when especially accellerating in first and second gear but once I got going it stopped. The strong vibration even comes through the gas pedal and interior. The engine also stumbles and hesitates when out of gear. I never had these symptoms before the switch. Could my Infiniti dealer not installed them properly? Is that possible? I'll call them early in the morning but I was wondering if anyone would have any ideas what it could be. I'm freaking out a little and don't want to do serious damage just driving it an hour to the dealer.
Thanks for any response.
on
Originally posted by BrianLG35C
Anyone have any ideas. If it's the Cats causing the vibration, why do I have the engine symptoms? Could it be the ECU resetting?
Ian
on
Originally posted by LowUFO
It sounds like it might be an exhaust leak. Try looking under the car to see if you have any carbon coming from any of the gaskets. Try tightening the bolts, etc. Did you use new gaskets? They may need to be replaced. I'd start there. I had a similar problem with my Integra Type R, and it was a crack in the flange, and it was leaking. I had to have a replacement CAT sent.
Ian
Ian
Ultimate cats are great. They are not loud and this is the only mod I notice a perceiveable difference. 3K and up is insane with the Ultimate cats. The build quality and fit is also excellent. I swear by them now.
on
I have the RT cats and NISMO exhaust and like them
Yes they can be a little raspy in the higher RPM's but its never bothered me.
I wouldnt say it's a crappy sound at all.
I'd love to hear a sound clip of the Ultimate Cats and the NISMO exhaust
are they as loud as the RT's ?
dat title
on
Originally posted by owali1
Where did you all buy the Ultimate cats? I was thinking about getting some as well.
http://www.z1auto.com/
UltimateSleeper
Re: Traded RT Cats for Ultimate Cats!
You can of course check whether this is in fact the problem by taking off the cats and looking to see if there were any marks/scratches (from rubbing, hitting) made on either/both the cats or the chassis wall itself.
Gurgen
on
Re: Re: Traded RT Cats for Ultimate Cats!
Originally posted by gurgenpb01
If there is vibration, i can ALMOST GUARANTEE you that the cats are hitting the body wall of the car. My G had the same problem as I was trying to put on/fit the Crawford (and later RT) cats designed for the Z. It's a relatively easy fix: you have to hammer in or somehow modify the body wall to make room. In my case, we made an "X" incision in the wall (actually a double wall on that part of the chassis - so definitely no big deal) and hammer in the triangular "flaps" create by the incision. This gave us the necessary room. Problem solved.
Gurgen
Gurgen
on
they could be of slightly different shapes. My RTs ALMOST fit, while my crawfords (slightly larger size) are the ones that really required a modification.
