Creaking noise in rear
Anyone else having this problem? It's coming from the interior near or in the sway bar I think.
Mine started a month or two back. Not sure what it is, but seems to be coming from the left hand side (driver's side). Has the source of this noise been tracked down? Anyone?
Re: Creaking noise in rear
Originally posted by Satchel Anyone else having this problem? It's coming from the interior near or in the sway bar I think. |
I have a click or pop from the rear usually when the chassis is subjected to a twisting force. I think I have it isolated to rear roof cross member joint, possibly at bolts, four on each side. Next time I have the headliner off, I plan to try locktight on the bolts.
I had creaking in the right rear. I took it in at the same time as my tranny. Turned out to be something wrong with the bolts in the axle which is also getting replaced under warranty.
Originally posted by Donkeypuncher I had creaking in the right rear. I took it in at the same time as my tranny. Turned out to be something wrong with the bolts in the axle which is also getting replaced under warranty. Sorry, it was something with the axle joints. |
i have it also they told me its something in the roof or something. i dont exactly but it is under warranty so gonna take it in someday soon
I had the same problem took it in they said it was the sway bar, two days later the sound is back.
Here is added twist. I have the problem. I only hear it when running wider-than-stock wheels/tires. It disappeared when I replaced wider wheels/tires with OEM wheels/tires. The noise returned when I put the the wide wheels/tires back on.
Re: Re: Creaking noise in rear
Originally posted by samlb Here is added twist. I have the problem. I only hear it when running wider-than-stock wheels/tires. It disappeared when I replaced wider wheels/tires with OEM wheels/tires. The noise returned when I put the the wide wheels/tires back on. |
i have the same problem, taking it on monday, coming from the rear right near the strut bar
Just so you know, my entire rear assembly has come loose. You can move the entire thing by grabbing the wheel and pushing it back and forth. I'm going to the dealer tomorrow to have them check it out. I believe it to be a bad IRS bushing or bolt that is now missing. It's really bad under heavy acceration...
