Damn it my window wont go up....
Old Jun 30, 2005 | 03:50 PM
tim quibodeaux's Avatar
tim quibodeaux
Default Damn it my window wont go up....
This afternoon I rolled my widows down with key fob to get the hot air out before i got in. Then when i got to the store i went to roll it up and it didnt work. Everything else on the door works except the driver side window. Anyone else have this problem, If so what is it? Thanks
Old Jun 30, 2005 | 04:20 PM
Reese's Avatar
Reese
Is the window lock on? BTW the key fob will not roll up the window, it will only roll it down. You can stick your key into doorlock on outside and turn it to lock door and hold it in that position to roll up window or vise versa to roll it down. If that doesn't do it..I can't help ya. Good luck
Old Jun 30, 2005 | 04:34 PM
Z04's Avatar
Z04
it is the window motor regulator. had to get mine replaced on both the driver and passenger side. (about a year apart) it is covered by warranty so no worries.
Old Jun 30, 2005 | 04:37 PM
Reese's Avatar
Reese
Wow, that sucks. But at least its under warranty.
Old Jun 30, 2005 | 04:39 PM
tim quibodeaux
could it be a fuse? If so anyone know which fuse it is? It dosn't say on the fuse panel.
Old Jun 30, 2005 | 05:48 PM
glogan's Avatar
glogan
Default Window
Take it to the dealer, it's still covered by warranty right? I had a driver side window problem as well. Whenever I pull the switch to automatically roll up the window, it goes up then roll back down halfway. Took it in and dealership fixed it. Mechanic said it was just a minor adjustment.
Old Jun 30, 2005 | 06:20 PM
tim quibodeaux
its still under warranty
Old Jul 1, 2005 | 10:24 PM
eddytsi's Avatar
eddytsi
it just happened to my driver side yesterday. my passenger side is fine though.
just curious, where on the car would they fix it? (do they take out door panel?)
Old Jul 1, 2005 | 11:00 PM
glogan's Avatar
glogan
Default window
From the looks of it they pulled the switch panel out. I think it took them but 10-15 minute
Old Jul 2, 2005 | 06:57 AM
Z04's Avatar
Z04
yeah, my passenger side did that before it just quit completely.
Old Jul 2, 2005 | 06:58 AM
Z04's Avatar
Z04
to replace mine they took off the door panel and window then removed the faulty regulator. took them about 30 minutes
Old Jul 2, 2005 | 04:51 PM
eddytsi's Avatar
eddytsi
it had to happen on a sunny 80 degree day, i had no choice but to turn the a/c on......what a bummer.
Old Jul 2, 2005 | 05:47 PM
NTRIGUE's Avatar
NTRIGUE
1. Turn key clockwise in lock?
2. Check window lock?
3. Place passenger fuse in driver fuse slot?
4. Bang right above the controls while holding the switch up?
None of this worked then its the TSB for the motor bring it to Nissan.
Old Jul 2, 2005 | 06:05 PM
Monsta's Avatar
Monsta
HAHA If all else fails, hit that B***H! I had to do that w/ mine. I would hold the switch and close the door a lil harder til the dealer got my motor in.
Old Jul 3, 2005 | 08:14 PM
Silverstone_350's Avatar
Silverstone_350
yea this happened to me this past week. i'd push the button all the way so that it automatically rolls up, n then it would reopen half way. finally last sunday the window motor took a **** n left my driver side window stuck open. took it to my dealership and it took the a55monkeys a whole week to fix. they ended up replacing the motor and regulator.
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
350z82
Oct 1, 2015 06:25 PM
AP350z223
Sep 8, 2015 04:38 PM
