Idle noise
Old 03-09-2008, 08:02 AM
Corradoslc7
Corradoslc7's Avatar
I'm sure it's more expensive for any auto manufacturer to equip a car with a DMF compared to solid flywheel. Most car companies are using DMF's today so compared to other cars, Nissan's DMF is probably equally priced.
Old 03-09-2008, 10:09 AM
ladyzed
ladyzed's Avatar
Thanks
Old 03-10-2008, 08:04 AM
buckeyeZ
buckeyeZ's Avatar
yea they are more expensive than regualr flywheels.....my tiburon had a dual mass flywheel on it stock and my clutch failed on it....was going to be like 800 bucks just for another stock flywheel.....so i went with ACT.....stage 2 kit(flywheel, TOB, Clutch disk) for only 450
Old 04-06-2008, 05:39 AM
Bananas!
Bananas!'s Avatar
I don't get it,
I've had manual transmission cars all my life. Changed more than a few clutches,transmissions, flywheels, etc. I've never seen a drive train thay makes the racket that these Z's make. As far as a solid flywheel making more noise than this dual mass junk, why is that? I've never had a dual mass flywheel before but, of the solids that I've had, not one ever made a sound. Occasionally when a throwout bearing went bad and was noisy, that meant that it was time to change it.
As far as these lousy transmissions are concerned, somebody needs to make an adapter kit to couple up a t-6 to the Z's 3.5.
Bananas!
Old 04-07-2008, 02:32 PM
Z Infidel
Z Infidel's Avatar
I have this same issue but you have all covered it so well I have nothing to say but this, thanks!
Old 07-02-2008, 10:35 AM
NewZ84
NewZ84's Avatar
return of the thread....
quick questions. anyone know if the dealership will replace the clutch/flywheel due to this noise and will it be covered under the 60K mile drivetrain warranty???
Old 07-02-2008, 12:05 PM
sharples2
sharples2's Avatar
Originally Posted by toy4two
I'll take these differences if it means having to hear a faint noise at idle with the clutch out, the only time I can really hear it is sitting in a drive thru and have my window down while it bounces off the fast food building.
Soo true. That is the only time I hear it when I get my coffee in the morning at DD.
Old 03-11-2010, 12:22 AM
orangeflash
orangeflash's Avatar
wow, I havent checked this thread in a while. Still have the problem. Never really looking into it. Ohh well, im sure i need a new clutch soon.
Old 03-11-2010, 08:55 AM
ZKansasZ
ZKansasZ's Avatar
change the clutch will solve the sound problem, the end.
Old 03-19-2010, 02:46 PM
BJJ Gi Choke
BJJ Gi Choke's Avatar
yep mine does it too, its normal for these cars. Nothing to be worried about, doesn't effect reliability in the least. These cars have carbon drive shafts, dual mass flywheels, many things you won't find in your regular old car, there is going to be differences, personally I'll take these differences if it means having to hear a faint noise at idle with the clutch out, the only time I can really hear it is sitting in a drive thru and have my window down while it bounces off the fast food building.
Always does this when I'm next to a wall.
Obadabot
06-18-2023 11:31 PM
liqalu04
01-02-2022 12:58 PM
11-09-2020 10:27 AM
hulkout
Tuning
09-30-2015 12:33 PM
Quick Reply: Idle noise
