weird tranny noise??
Old Aug 3, 2008 | 11:09 PM
SharX59's Avatar
SharX59
Exclamation weird tranny noise??
I just bought a 2007 Nissan 350z and there is a strange rattling noise when i shut the car off. Not only that but there is another knocking sound it makes wen it is in neutral at idle which goes away when i depress the clutch. Does this have something to do with the 2007 recall of the clutch slave cylinder?
Old Aug 3, 2008 | 11:18 PM
Spork's Avatar
Spork
Normal clutch noise.
Dual mass flywheel.
Either get used to it, or buy a lightweight flywheel and get used to flywheel chatter.
If you want a quiet car... don't get a Z... let alone a sports car.
Old Aug 3, 2008 | 11:22 PM
SharX59's Avatar
SharX59
thanks i just wanted to make sure. i never had a sports car. before this i had a jeep wrangler.
norapat01's Avatar
norapat01
lightweight flywheel will just amplified the noise. I got a nismo lightweight flywheel on, and it make all the same noises as you describe above. Just relax, there's nothing wrong with your car.
Old Aug 3, 2008 | 11:28 PM
SharX59's Avatar
SharX59
thank god i was really worried at first. but should i take my car to a dealer since the vin # falls under the recall for the clutch slave cylinder?
Old Aug 3, 2008 | 11:31 PM
norapat01's Avatar
norapat01
sure, why not? Since it's going to be free anyway
Old Aug 3, 2008 | 11:32 PM
SharX59's Avatar
SharX59
yah i guess ill call tomorrow
Old Aug 4, 2008 | 12:22 AM
Blazemaster's Avatar
Blazemaster
if you're really that worried about that noise, you can just fully depress the clutch in, and then turn off the ignition. the rattling noise won't happen when the clutch is fully depressed because you stop it from spinning right away when you depress it.
Old Aug 4, 2008 | 12:40 AM
SharX59's Avatar
SharX59
the only thing i want to make sure is that it wont become a big problem or cause any problems in the future.
Old Aug 6, 2008 | 12:50 PM
OliverH22's Avatar
OliverH22
Don't worry, you're fine...
I had the same question and doubts when I bought the Z.
So far 13k miles and perfect.
Today I dropped off my Z @ the dealer because my clutch pedal was making an annoying clicking noise when I'd let it of slowly and they said they are changing the Clutch Slave Cylinder. (Recall maybe?! )
Old Aug 6, 2008 | 06:11 PM
novakain's Avatar
novakain
thanks this answered my questions too...
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
