Car Won't Start When Hot!!
Hi guys: i have a greddy Twin Turbo Set-up with the emanage ultimate, my car runs great with no problem at all, one day when i went to the gas station after 10 minutes when i get the car it cranks, but wont start, i have to wait like ten minutes until the engine gets cool and stasrt perfectly.
i chek the coils, change the spare plugs, change the coolant sensor, i check the coolant, change the thermostat, i check the baterry grounds, when i check the scanner it says "Advanced Overtiming Bank 1" i dont remember the code number and error code PO300 random Misfire. the car runs great.. any suggest apprecciate, thanks. |
See if Nissan will do a charging system test on the Z & scan for current or history code.
I already check with a scanner...
next time it happens and you have a friend around try pulling a plug and starting it and make sure you're getting spark and fuel. Might be a problem with your tune also.
Thanks island03z i already make it, when the car is cold its spark but when the engine is hot i doesnt make nothing at all. i dont make anything with the emanage the car make this problem without toching the emanage...it could be the cam sensor? thanks.
| All times are GMT -8. The time now is 07:31 AM. |
