MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   AUto transmission doesn't down shift, doesnt hold RPMs higher than 4.5k (https://my350z.com/forum/maintenance-and-repair/482314-auto-transmission-doesnt-down-shift-doesnt-hold-rpms-higher-than-4-5k.html)
alex1089 Apr 10, 2010 01:59 PM
Can anyone help? Monday ill take it to the shop to get it checked but until then can anyone help.
I have an 05 Z automatic 35th anniversary. This has started happening for about a month now. The car feels so much slower. Basically cruising on 5th gear and if i slam the gas it doesnt shift down anymore, just stays in 5th. Also it doesnt hold gears long enough to reach even 5k rpms...
In at 36k miles. I havent had the fluid replaced but ill have it done on monday at z garage in san jose. Also is it better to flush transmission fluid or just drain and refill?
Can anyone suggest anything? I havent been driving it hard at all.
Thanx
Entaille Apr 10, 2010 02:06 PM
a flush is better, but when the fluid costs like 1X$+ a quart it can get expensive. a lot of shops struggle to flush it as well, they can only drain out X amount of quarts without the proper tools, so you may just be replacing as much as you can.
too me this doesn't sound like a fluid issue, but for your sake I hope it is that simple. good luck!
alex1089 Apr 10, 2010 02:28 PM
Lol thanks for the support. Do you thinks its a computer issue? What if i reset it?
davidv Apr 10, 2010 03:09 PM
Sounds like the transmission is broken. 60 months is the drive train under warranty? Nissan may give you a new one.
alex1089 Apr 10, 2010 03:38 PM
I have a salvage title. They said its voided because of that.
Entaille Apr 10, 2010 04:29 PM
let us know of the outcome sir.
alex1089 Apr 10, 2010 04:47 PM
It works fine if i downshift it manually. Im hoping its the computer. Ill try resetting it tonight
davidv Apr 10, 2010 08:50 PM
Oh sorry about that.:(
