My z doesnt charge and cluster doesnt work!
So I have a 2007 350z and It has many electrical problems the cluster doesnt work and the gauge that has the timer and how fast you are going doesnt work the oil and volts work but they dont light up and it doesnt make the beeping sounds when the key is in the ignition I know that it has to do with the A/C amp. My other problem is that my alternator doesnt charge the battery I took it off many times and took it to autozone for a test and it works! But I put it back on and it doesnt charge my battery and the battery is new and so is the alternator! Checked all the fuses 1 by 1 and grounds but nothing! Here is where it gets weird sometimes when I hit speed bumps it starts charging but then it stops charging after a while any suggestions on what I should do? Sorry for the long thread ):
AndreZ Cadena
05-16-2008 05:51 AM
Boneout JZA80
Southern California
03-19-2007 09:52 PM
