MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   locks, windows, seats won't work (https://my350z.com/forum/maintenance-and-repair/550343-locks-windows-seats-wont-work.html)
BigJim Mar 9, 2012 05:53 AM
After parking the Z yesterday, I went to get back in and the remote wouldn't unlock the doors. After using the key, I found the windows wouldn't go down, the seats wouldn't move and the door locks wouldn't work. Oddly, the heated seats work. Aside from that, the car drove.
I researched a few threads but couldn't find a solution. All signs point to a blown fuse, a relay or a BCM issue. The BCM fuse looks fine. I believe all of these things work on the same system and are connected to the same electrical problem.
Has anyone had this issue and resolved it? Nissan wants $100 just to look at it.
R350Zz33 Mar 9, 2012 06:05 AM
so far we know its a nissan and a z and locks windows and seats dont work. its probably a fuse get off ur lazy ass and start checkin them
BigJim Mar 9, 2012 07:08 AM
Wow, didn't think of actually checking the fuses. No $hit a-hole. I checked the fuses. They look fine as I mentioned.
Vivid Racing Mar 9, 2012 09:01 AM
Fuses can LOOK fine and still be bad. Test for power on both sides of the fuse OR pull each fuse and check resistance across it.
More than likely it's a relay. Test your relays as well.
BigJim Mar 9, 2012 09:25 AM
Where would that relay be located?
blAk mAx Apr 28, 2012 03:17 PM
Hello
