MAF sensor harness??
Hey guys I have a Fujita Sri on my z and I found out the hard way that it was a little too close to the strut tower, and the connector wires to the mad sensor harness are a little sliced up, the car bogs out a little at idle, and the check engine light is on now.
I heard that they don't make just the wiring harness for our cars, so what should I do? I heard this can be a common problem for z's with aftermarket intakes, the intake was adjusted so once it's fixed it won't happen again, but it needs to be fixed! Thanks! |
Why not just solder new wire? electrical tape it, and wire loom. not that hard.
A couple shops told me they don't think it can be done because the wire is fraying out of the connector, it's not like its further down, where you can resolder it. You would have to reconnect the pins.
Someone helpppp lol |
Im having the same problem with my HR, i believe the hood shut on one of the connectors and snapped the plastic and destroyed some of the wires. I ordered a new connector ( https://www.michiganmotorsports.com/...IaAljaEALw_wcB ) and plan to solder the wires back together. Lets see how it turns out.
