MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   Can't shift into 1st (https://my350z.com/forum/maintenance-and-repair/573048-cant-shift-into-1st.html)
skroth1234 Feb 14, 2013 12:53 AM
my 350z has been fine up untill about 4am. I went outside, started it everything normal. I take off in 1st its fine. i slow down to go over speed bump so i try to go into 1st and it wouldn't go unless i came to a complete stop... I have done some research and people keep sayin this is normal a lot of cars do this. but mine didn't before, up until now. and some other people are saying it is the oil viscosity to use a 5w oil... can someone please tell em why my car is acting like this? Thanks
jtbinvalrico Feb 14, 2013 03:54 AM
Have you done any recent mods or adjustments to the clutch or tranny?
iideadeyeii Feb 14, 2013 05:55 AM
Does double clutching or rev matching work?
VO... Feb 14, 2013 08:10 AM
Thread moved.
Two things:
1. Yes sir, it is pretty normal to have to come to a stop when placing back in 1st. It is possible to place back in 1st when at a crawling speed, but you're going to get resistance. You should just place it in 2nd. The Z has enough torque to not bog down.
2. The engine oil will have no bearing on your ability to shift. This will be the transmission fluid. I notice you mentioned 4am. Was it cold outside? Colder days will affect shifting...
KornerCarver Feb 14, 2013 08:11 AM
You use 5W oil in the transmission???????
