MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   Engine won't start no Codes (https://my350z.com/forum/maintenance-and-repair/577069-engine-wont-start-no-codes.html)
HOODEY Apr 22, 2013 07:11 AM
I have a 2008 Hr which I have two outstanding items to fix.
The rear suspension and getting engine started.
The engine turn over okay but does not start. I can swear I hear it trying to fire but never runs.
While cranking the oil pressure rises as expected.
There are no engine codes. The security light goes off when ignition on.
The car has been sitting since November.
Any ideas?
HOODEY Apr 23, 2013 05:14 AM
It is clear to me that for such a popular car there are very people who are able to resolve it problems.
KornerCarver Apr 23, 2013 05:18 AM
I suspect you have a security issue. You will probably need to take the Z to a dealer to get the issue resolved.
HOODEY Apr 23, 2013 07:37 AM
If there is a security issues would i not see NATS codes and would the security light not stay on?
HOODEY Apr 23, 2013 05:30 PM
Guys can you tell me what should happen if I remove the two bolts on the damper and remove it from the rail then switch the ignition to on but not start?
I did this but I am not seeing any fuel coming from the damper? I can hear the fuel pump activate and then cut out but I am not seeing any fuel at the end of the damper.
b18ccivics Apr 23, 2013 05:42 PM
put some gas in it... Looks like you are on the right track...
HOODEY Apr 26, 2013 05:56 AM
Problem solved..:thumbup: And no I did not have to go to a dealer and no it was not a security issue.
SQuaLZ Apr 26, 2013 06:25 AM
What was the problem? Interested.
meanz Apr 26, 2013 08:07 AM
+1^
skeetzee Apr 26, 2013 08:11 AM
fuel pump?
350Zdj Jun 5, 2013 11:41 PM
wow, thanks for sharing, OP :/
