Help diagnose A/C problem
Old 06-11-2018, 07:35 AM
Z33Garage
Z33Garage's Avatar
I have been scouring the FSM and cannot find the self diagnose procedure. All I find is the SES light procedure, which I am assuming is not the correct one. Any links to the procedure and the faults?
Old 06-11-2018, 01:52 PM
Z33Garage
Z33Garage's Avatar
NM FOUND IT!
2005 350z
- High side (98 psi) (calls for w/ amb temp 152-194psi) idle
-low side (45psi) (calls for w/ amb temp 29-42psi) idle
-Pressures do not change with engine RPM
-BLOWS hot air
Compressor clutch works, in cabin blowing motor turns on, AC control switches work, all AC fuses and relays work.
-No leaks are found using UV light
-Compressor does not feel warm to the touch indicating mechanical binding of some sort.
-condenser is clean and free of debre
-System became hotter and hotter over the course of a week, till it finally blows only hot air.
Any ideas? I am literally about to change it all.
Old 06-12-2018, 08:23 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
Originally Posted by Z33Garage
NM FOUND IT!
2005 350z
-BLOWS hot air
I don't usually advocate "throw parts at it" but, it sounds like it might be temperature switch/sensor. Possibly ambient temp switch (up front, down low in front of radiator.) No guarantees but a faulty ATS can cause problems such as yours. Not too expensive a part to replace.
Old 06-12-2018, 10:26 AM
zakmartin
zakmartin's Avatar
Based on your description that it's stuck on blowing hot air only, it's either what Mic said or it's a stuck blend air door or bad blend air actuator. It could also be a faulty temperature dial (I believe you can test the resistance on the dial with an multimeter.) Hopefully, it's not a failed A/C amp.
Honestly, since the failure has been incremental, I'm placing my bets on the blend air door or actuator, because I've seen that happen a few times before.
Old 05-08-2021, 12:11 PM
sk8rdude8754
sk8rdude8754's Avatar
Default Help
NM FOUND IT!
2005 350z
-BLOWS hot air
Did you figure it out? I have same year and same problem! 05 350z 98psi blowshot
Old 05-08-2021, 12:59 PM
Z33Garage
Z33Garage's Avatar
Yeah I did. Turns out my compressor was shot. So i replaced that, the AC condenser and dryer.
I made a video of the repair on my channel.
Uriyo_
09-08-2021 08:46 AM
08-06-2021 06:19 AM
Quick Reply: Help diagnose A/C problem
