MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   Car won't start after rebuild. (https://my350z.com/forum/maintenance-and-repair/581831-car-wont-start-after-rebuild.html)
zach711f Jul 21, 2013 10:57 PM
I hate to make this thread...I just got my short block back from forged. Heads reworked locally. Just Put the whole motor together and stuffed her in. I got spark and fuel...she cranks over but doesn't run at all. I followed my Haines manual for timing then manual turned the crank a million times to make sure it wouldn't hit valves. Everything worked before I rebuilt motor I doubt a sensor is bad. Flywheel only goes on one way with down pin hole so that should be right. Any help would be great!
350Zdj Jul 21, 2013 11:46 PM
subscribed.
I'm in the same situation right now.
Hope you get it fixed soon man.
What does the scanner say?
zach711f Jul 22, 2013 05:47 AM
My little pocket scanner dosent read anything wrong
zach711f Jul 22, 2013 06:12 AM
I have my whole front clip off the car. So no radiator and fans hooked up. I dunno if electrically those need to be on to connect a circuit. I just wanted to start quick then shut off.
Bret86944 Jul 22, 2013 06:28 AM
Are you sure you have fuel at the injectors? I remember when I re-built the head of my old car it took a while for the fuel to fill the fuel rail back up. I had to put the pedal to the floor until it started catching.
zach711f Jul 22, 2013 10:18 AM
I'm 100% positive
djamps Jul 22, 2013 10:29 AM
my guess is either valve timing chains aren't aligned or sensors aren't working right. ECU probably won't throw codes for wrong timing at cranking speeds.
zach711f Jul 22, 2013 02:59 PM
My timing was 180 degreesbackwards on the intake csm sprockets..il try stsrting it again tommarow after I let rtv cure.
Classy Jul 22, 2013 04:38 PM
Check your valve cover gaskets, my car sounded like it wanted to start but just wouldn't kick over, turns out in the excited end of my motor build we put the valve cover gaskets in badly and one was torn and the other ballooned out the side. Replaced both and fired up first try
zach711f Jul 22, 2013 04:41 PM
That's weird. Mine are good to go though. My timming was way fawked up. I think that was the problem..il update tommarow. Il take some pictures too.
binder Jul 22, 2013 07:44 PM
The car will start just fine with valve covers removed so that definitely wasn't your problem. Maybe when replacing them you fixed something else like a vac leak in the plenum or a loose connector.
Timing being 180* out would post a big problem for the sensors when trying to read data and send spark.
zach711f Jul 23, 2013 05:10 PM
So the car runs and drives great. Timing was my issue. Started right up. At first I heard ticking from the heads and I immediately thought the worst. But I also used a shyit ton of assembly lube and once it worked itself out it purrs like a cat in heat. The rear main seal I just put in is leaking already though..:dunno: o well ill fix that after I get back from FE school.
zach711f Jul 23, 2013 05:36 PM
6 Attachment(s)
Drove for 20 mins like a boss
Attachment 452191
Attachment 452192Attachment 452193Attachment 452194Attachment 452195Attachment 452196
MR RIZK Jul 31, 2013 01:43 AM
Search this forum in regards to the rear main replacement. There are some tricks in putting them in without lipping the seal or dropping the engine again.
zach711f Jul 31, 2013 07:14 AM
Will do. I think I can do it buy removing the upper pan and transmission but have not looked into it. I dunno what I did to frigg this up. I put the thing on while on the engine stand. Clean surfaces. Seemed straight forward. Won't know till I tear into her again.
zach711f Jul 31, 2013 07:17 AM
O and if anyones wondering why in my final pics the timing cover isint burnt copper, I'm a big dumb animal and ripped it in half while fixing the timinf issue and had to go buy another one...don't ask..it was late and I was tired and getting grumpy.
JaE35z Jul 31, 2013 07:18 AM
Z looks great, happy you got her running
zach711f Jul 31, 2013 07:26 AM
Thanks. Its about time I start breaking shyit again. Been down for a few months waiting on parts.
zach711f Jul 31, 2013 07:33 AM
1 Attachment(s)
Doing a light breaking 500 miles. Attachment 452216
MR RIZK Jul 31, 2013 02:14 PM
If you push the seal on straight when it is on the stand it will lip. When I rebuilt my engine i had a rear main seal leak. Got to a point where it was a steady stream of oil. After I removed the rear main I noticed that I lipped the seal which caused the issue. After searching the forum there were many posts on the best way to replace the seal. In my case I dropped the upper oil pan, removed the locating dowels and gently worked the seal on a slight angle to reduce the likely hood of it lipping again. Punched the dowels back in and put all back together. I did this in the car but was a pain in the butt. Need a engine crane to lift the engine and drop the cross member about 2 inches.
