MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   Drive shaft doesn't fit??? (https://my350z.com/forum/maintenance-and-repair/589393-drive-shaft-doesnt-fit.html)
iamdigital Jan 18, 2014 04:20 PM
Gang,
Going out of my fkn mind. Drop'd the engine/tranny on my 05 AT and now I can't get the drive shaft back on the diff.
Very slight possibility I accidently swapped it for my 03 MT drive shaft but same part number according to Courtesy. I've burned days trying different ways to get it in. Any advice?
Cux350z Jan 18, 2014 04:46 PM
is it a length issue of mm or inches? Can the engine move forward some?
I thought automatic transmissions required the drive shaft to stay in else fluid would come out?
myfirstzcar Jan 18, 2014 06:16 PM
Are you sure the slip yoke is going in as far as it used to? Maybe there's a foreign object inside the slip yoke.
iamdigital Jan 18, 2014 07:20 PM
It's flush on the tranny side so not an issue there
Cux350z Jan 18, 2014 07:34 PM
So is it an issue of a mm or two or an Inch or two?
you don't have a go drive shift on a 350z right?
