Upper oil pan replacement
Old 04-13-2014, 06:01 PM
florotory
florotory's Avatar
Default Upper oil pan replacement
So today while changing my oil I decided to Change out a bad oil sensor. Ya that was a huge mistake. My question is , has anyone had any success with changing the upper oil pan out without pulling the motor?Thanks
Old 04-13-2014, 06:32 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
Either pull the motor or drop the front subframe with the motor supported. Its gonna be a huge pain.
Old 04-13-2014, 06:42 PM
florotory
florotory's Avatar
That's what I was afraid of. Now just to decide which way is easier, Subframe or pull motor. I wish I woulda read the thread on just adding the adapter to the oil filter and relocating the unit
Old 04-13-2014, 07:35 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
pull the block...and while the block is out install a built motor and nothing goes better with a built motor like twin turbos...
Old 04-14-2014, 02:54 AM
florotory
florotory's Avatar
I wish I could. Too many other toys in the garage. This is my dd
Old 04-14-2014, 06:45 AM
florotory
florotory's Avatar
I gona look at it today to see if it will be easier to pull the subframe and do it that way instead of pulling the whole motor.
Old 04-14-2014, 08:42 AM
Cux350z
hatersgonnahate
Cux350z's Avatar
pulling the motor would be best. You have a lot of sealing surfaces to rework.
Old 04-14-2014, 08:46 AM
florotory
florotory's Avatar
Ill probably do that. Ive been reading on here and people are saying that the upper oil pan is around $100 from the dealer. The dealer near me wants $300 for it and I saw online at another dealer it was $205. Anyone have a good source for the upper oil pan? Thanks again
Old 04-14-2014, 09:31 AM
JCCLARK
JCCLARK's Avatar
I just removed my upper oil pan to get my timing cover installed.
Once you jack the engine up using a engine support bar like the one in the picture,
and pull the front cross-member, it's not to bad.
I got the support bar at Harbor Freight for about $70.00
Attached Thumbnails Upper oil pan replacement-img_2996.jpg   Upper oil pan replacement-img_3002.jpg
Old 04-14-2014, 10:01 AM
ericjackson
ericjackson's Avatar
You could disconnect the trans, exhaust and motor mounts and just lift (with a hoist) the engine 6 - 12 inches or so. i did it without disconnecting anything and could only get it about 4 inches, but i was able to pull the upper pan and clean the gasket material and re-gasket it. It was a huge pain in the ***. but so is pulling the engine.
Old 11-27-2018, 08:18 AM
RobPhoboS
RobPhoboS's Avatar
I KNOW this is an OLD thread BUT JCCLARK's photo really helps my question here.
I've got to do something similar (replacing oil pump, timing chain etc), and I am buying the same kind of engine support bar.
Where is good to support it on the engine ? + straps or chains ?
Old 12-13-2018, 06:00 PM
Crawford842
Crawford842's Avatar
I’m a bit late but I’d like to answer what I did both times I removed the upper oil pan. I used an engine hoist. Somehow I got it out the first time without removing the crossmember but I couldn’t remember how on the second time so I dropped it. I used a seat belt to secure it as I couldn’t find a good spot to attach my load leveler. And I think I just wrapped it around the exhaust manifolds.
RobPhoboS (12-17-2018)
Old 12-17-2018, 07:42 AM
RobPhoboS
RobPhoboS's Avatar
Many thanks !
I'm doing the work from this weekend onward. I have the support bar, and I bought a couple of 1ton supporting straps too, and from what I can see they'll go under the engine mount brackets.
I'll link up some photo's once I get down to it !
Old 02-11-2019, 06:02 AM
Enriquez2000
Enriquez2000's Avatar
Oops
Old 04-17-2019, 12:28 PM
Antony Ng
Antony Ng's Avatar
Hey JCCCLARK. Thanks for posting this on the forum. I am planning to reseal my upper oil pan as well. Which areas did you chain your engine to support it? Thanks!
Old 11-01-2019, 06:20 AM
Dcrunning
Dcrunning's Avatar
Can you tell me how you secured it to the engine? Im about to do this weekend and remove the subframe but I cant find any resources on telling me how to secure the engine. I read that Nissan uses engine slinger. Did you buy them? These mount to the engine it seems. Thanks in advance.
07-10-2022 07:44 AM
burglapfd
12-06-2020 01:04 PM
04-04-2016 07:52 AM
350z82
10-01-2015 06:25 PM
Quick Reply: Upper oil pan replacement
