MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   Drivers side doesn't open when it's hot (https://my350z.com/forum/maintenance-and-repair/603641-drivers-side-doesnt-open-when-its-hot.html)
Moe747 May 7, 2015 02:56 PM
As the title says, my drivers side window doesn't open when it's hot outside but my passenger side window operates fine. I'm suspecting it's a motor issue because I looked at the switch yesterday and it looks fine. Anyways the issue isn't present in the morning when it's cooler so I thought it was strange.
Spike100 May 7, 2015 04:16 PM
^^ You are correct. It is a motor issue. There is a thread here describing a repair on the existing and failing motor. I did that and it worked, but just for a short time.
You are better-off replacing the window motor with a new one. I did that (new motor) after the "fix/repair" that failed within 4 months. The motor replacement has been good for 6 plus years and still going strong. --Spike
Moe747 May 7, 2015 04:17 PM
What's the brand of your window motor?
Spike100 May 7, 2015 04:30 PM
I installed an OEM Nissan window motor. I do not know the OEM window-motor supplier for Nissan. I doubt that is important.
The significant point here is that cleaning the coil on your existing window motor is a temporary fix that is good for less than 4-6 months. The thread describing the "fix" does not acknowledge this. Be aware that anything less than replacing the motor is a temporary fix. --Spike
rich2342 May 8, 2015 03:13 PM
Mine just stopped working today for some reason. Was working fine this morning.
Is there a DIY for this?
Spike100 May 8, 2015 04:09 PM
Yes. It's a Sticky in this sub-forum. Just look immediately above and you will see it.
guitman32 May 9, 2015 09:49 PM
Go OEM for the replacement is my recommendation. It is worth the money if you want to do the job once and not worry.
