Bent valves?
Old Aug 19, 2015 | 09:57 PM
juicyz33's Avatar
juicyz33
Default Bent valves?
So as i was approaching a red light my car turn off out of no where? At first i thought it was gas because it cranked and was trying to turn on so i repeatedly tried turning it on but didnt work until i pulled over to the side and gave it another shot and it bearly turned on, so then i thought maybe my clutch gave out because i heard a nasty slapping noise, i drove it home like that not trying to go fast, i kept it 35 and under to not mess anything up , the next day i took it to a shop to get it checked out driving it aswell carefully and the outcome was a broken tensioner , the upper left cam one , and the left cam chain was the one making the slapping noise because it was loose. Any chances the valves could have bent? The timing was off a tooth aswell so im going to have to set the timing. I drive a 03 enthusiast if that helps.
Old Aug 21, 2015 | 10:48 AM
zakmartin's Avatar
zakmartin
Yes, the 350Z has an interference engine. You may have bent valves. You or your mechanic can check for bent valves without removing the heads by doing a comparative leak-down test (it isn't that hard to do).
Here's a how-to guide link that shows you how to test for bent valves.
http://www.denlorstools.com/autoblog...n-timing-belt/
Rev_Night
Nov 7, 2020 06:00 PM
allmycarsdie
May 13, 2016 04:38 PM
Twenty4
Jan 17, 2016 01:20 PM
nanotech
Oct 2, 2015 05:02 AM
