Intermittent false start! Dealership might be screwing me? (Please help)
There are cliffs at the end.
Originally, my 2004 350z with about ~70k miles came with a cheap ebay key. 3 months after purchase my car would intermittently not start. It would crank, my battery seemed to have enough voltage, everything checked up except for the anti theft system that cut off my fuel pump. I went to a nissan dealership and they determined that they key was the culprit, so i got a brand new nissan certified key and went on my way. 7 months later the problem returned, i went to a different nissan dealership (back home) and they checked my nats, said it didn't have a problem, so they wanted to replace the IMMU ring in the ignition cylinder. If that didnt work then they wanted to continue on and replace the BCM, and if that didn't work then unfortunately the ECM afterso. The codes the brought up were as follows: P1615 (Difference of key) U1000 (CAN COMM CIRCUIT) I didnt have enough money at the time and the problem seemed to go away for about two months. When the problem came back, i went to a third nissan dealership and they tried testing for codes and ONLY the difference of key code came up. They then suggested i replace my key AGAIN since maybe the key the first nissan dealership gave me might be faulty :mad::mad::mad::mad: I'm now frustrated and confused as what to do. I know its a long read but how am i supposed to know whats wrong if a dealership cant even figure it out? I don't want to spend money where not needed. Cliffs: -Intermittent False start (cranks, wont start) -Got a new key (had an old ebay key before), worked fine for 7 months -problem came back, one nissan dealership told me to replace an IMMU ring, --another told me to replace my key AGAIN -very confused google wouldn't help much on the whole diagnosis aspect |
Originally Posted by lolwatbro
(Post 10652677)
The third dealership couldn't find the same code that the second dealership found.
(Post 10652698)
Were the dealerships ever able to "duplicate" the problem? That makes it difficult to diagnose as well. If you have 2 programmed good keys then try the other one when this occurs. If it works keep doing that until it fails. They'd certainly be able to find it then. Otherwise it would be just good guesses. |
(Post 10652677)
U1000 (CAN COMM CIRCUIT) Check engine light would not come on since it was intermittent. I am starting to notice that on Z33. if the part hasn't fully failed the check engine light or code wont appear so quickly. |
Help!
My car is doing the exact same thing. Did you ever get a repair? What fixed it? Help!
Originally Posted by Aprilmh1628
(Post 11034724)
Lol we need to know how and if you fixed it 🤣.....
if you ever get back on this site......... 10 years later 😴 Hello... hellllooo.. |
(Post 11034724)
Otherwise, there's little chance any of us will be able to engage with you on a potential repair to your ZR. |
Possible solution for this old ass intermittent start
I have a G35 every now and then I have the same starting issue. Usually when I do something out of the ordinary before I get in the car . , for example if I reach in the window and push the unlock button to get in the car, she will not start because she thinks I'm stealing her. It's happened a few times. Somebody told me when that happens just roll all the windows up, shut all the doors, lock it and unlock it with the key fob, open the driver door and shut it again, now she starts right up with no problem.
