Starter caked in oil. (PICS)
Old 04-13-2016, 12:54 PM
Bak3rme
Bak3rme's Avatar
Default Starter caked in oil. (PICS)
Hey guys, any idea how the starter accumulated this much oil on it?
I also tried to take a picture inside the bell housing in one of the pictures and you can see oil in there also (could be grease).
thanks!
(I just replaced my valve covers and oil cooler O-ring just this past week but have not turned the car on to see if it still leaks)
Old 04-13-2016, 01:49 PM
zakmartin
zakmartin's Avatar
Bad rear main seal maybe? That'd explain the oil anyway. If you can cram a scope into the pinion opening, you might be able to catch a glimpse of how much oil you have sprayed around your flywheel.
What's the year and transmission type of your vehicle?
Old 04-13-2016, 03:42 PM
Bak3rme
Bak3rme's Avatar
Originally Posted by zakmartin
bad rear main seal maybe? That'd explain the oil anyway. If you can cram a scope into the pinion opening, you might be able to catch a glimpse of how much oil you have sprayed around your flywheel.
2003 mt.
Old 04-13-2016, 05:38 PM
NissanZcrazy
NissanZcrazy's Avatar
Either rear main or rear of oil pan gasket.Sucks
Lithg
06-23-2016 06:48 PM
Exphiliac
05-02-2016 01:18 PM
kennyy
04-24-2016 03:10 AM
oTEMPE5To
04-11-2016 10:45 PM
Quick Reply: Starter caked in oil. (PICS)
