!!HELP, Oil Leak, What could be leaking!!
Hi, i had new valve covers installed and the leak continues, it seems to be leaking way below the valve covers, but it seems to high on the bell housing to be a rear main seal.
I put that paper to see if the valve cover would drip there but the paper is dry. What could this leak be, the valve covers look dry.:dunno::dunno::dunno: https://s29.postimg.org/u3xpx1m9j/OIL.jpgsube imagenes |
go get dye and uv light
I will, bot could this be a rear main, could the rear main leak upside the belhousing instead of leaking directly at bottom or the lower sides?
