2007 350z BRAKE lights wont turn on. ABS, VDC, SLIP lights are on
Old 08-29-2017, 08:30 PM
richardalvarez
richardalvarez's Avatar
Default 2007 350z BRAKE lights wont turn on. ABS, VDC, SLIP lights are on
Before i continue i would like to say that I am no expert with wiring whatsoever. This is my first time so dont get mad at me. So I tried installing the strobe brake light module to my Z and I think i messed something up. So i cut the black wire and the pink wire and connected that to the red and black on the module. After all of this, my brake lights will not turn whatsoever. Also, my ABS, VDC, and SLIP light came on! Where did I go wrong and how can i fix this???
Old 08-30-2017, 03:47 AM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
if you take out the crap module you put in, does everything work as it should?
Old 08-30-2017, 09:25 AM
zakmartin
zakmartin's Avatar
I bet your cruise control doesn't work anymore either. Chuck all that rice crap you just dumped on your car and return it to stock. The problem should go away.
Swaglife81
10-25-2016 06:31 PM
shadowoffair
10-18-2016 12:00 PM
the rook
10-10-2016 05:43 PM
nj1266
07-07-2002 06:18 AM
Quick Reply: 2007 350z BRAKE lights wont turn on. ABS, VDC, SLIP lights are on
