Oil Pressure
Oil Pressure
I have searched on the forum and nobody seems to have an answer for my question.
I just got my oil changed two days ago and when I come to a stop, my oil light comes on and my oil pressure gauge is at zero. I have checked my oil and it shows it being 3/4 of the way up the checkered area on the dipstick. I am seeing some people say oil pressure at idle is fine @ 0psi and some people are saying it should be higher than that. My oil pressure pretty much never goes above 60psi even when I am driving.
Here is a video posted by someone else but its pretty much the same issue I am having. He stated he replaced the oil sending unit? Does anyone have a recommended place to start?
What part do you not understand??? So the definitive answer is that my oil pressure SHOULD NOT be at 0 psi at idle? I cant seem to find a definitive answer. If that is the answer, then I KNOW I have a problem and I will replace the oil sensor. How much do they go for ~ $80?
If you're having difficulty using the wide array of internet search engines to find the price of the sensor in question, then my350z.com is probably not the place for you.
Whoa Kemosabe. I know you're frustrated with your oil pressure issue, but try to relax. Your oil PSI should never be 0. If you want a definitive answer, then you need to take it to a certified Nissan tech who can physically put their hands on your car as opposed to asking all of us "internet" mechanics who will basically tell you to just throw parts at it until the problem is solved.
lol - it's all good, broseph.
This guy used a mechanical gauge and got good readings so it turned out being the oil pressure sending unit: https://my350z.com/forum/maintenance...2003-350z.html
Part #: NIS-25070-CD00A
CZP (a vendor on here) has it for $42.
https://conceptzperformance.com/stan...0a_p_28462.php
If that doesn't work, it could be the pump, but that's less likely. I would try the mechanical gauge first to pinpoint the problem or you could just eff it, and buy a new sensor.
I would hope that Firestone would not have screwed something up during the oil change (like forgetting to refill the oil to the correct capacity, fraying or disconnecting the harness for the sensor, etc.). In order to check the oil level correctly, the Z needs to sit for a good while. I usually check my oil level in the morning before I start it for the first time after it sits about 12+ hrs. Otherwise, you will not get a correct reading.
If the oil level is good after checking it after it's been sitting for a while, then it's probably the sending unit which seems to be prone to failure, the wiring or harness connector, or the pump itself.
I don't know if the oil pressure would have a sluggish effect. Maybe?
Hmm okay. Ill check it tomorrow morning after its been sitting for a while. As much as I dislike dodgy mechanics I don't think they did anything wrong as I was having this same issue before I got my oil changed and I just added another half court of oil which after, still showed 0~10 oil PSI at idle but it must have just been enough to make the oil light stop coming on. After adding the half qt of oil my oil was near the top of the hashed mark on the dip stick 'H'. Its like my car needs to be filled almost to the 'H' for it to not throw some kind of low oil pressure warning. Does the oil HAVE to be changed when replacing the oil pressure sensor or does it just leak oil fast when you swap out the sensors and so most people just replace the oil at the same time? Im wondering because I just spent $90 to get the oil changed with full syn and if I can avoid having to go buy all new oil again that would be great.
I've been lucky enough to have never had to change my oil pressure sending unit. I imagine oil will leak out when you remove it to replace it. I suppose if you're reallllly fast, you may be able to salvage some.
Out of curiosity, what oil and viscosity did Firestone use?
$90?!? Yikes. I guess that's normal but I've always changed my own oil and filter with amsoil's top of the line products and it's not nearly that much.
110 degrees - but it's dry heat, right?
I'm not sure if it ever gets this cold in AZ, but if the ambient temperature never drops below zero degrees fahrenheit, you can use 10w-30 or 10w-40 according to the FSM. I know there are multiple threads out there about running different oil than the recommended 5w-30 based on oil consumption issues, but that typically plagues '06 revup owners for the most part.
Also this morning I checked my oil pressure after the car sat all night and it is FULL. Its matched up with the H on the dipstick. When I start it cold, it jumps up to about 60psi @ idle. Once warmed up, it then idles just above 0 psi so not quite at 0psi. Then under throttle (3000-4000rpm) it is at about 50-60 psi. This scares me because it doesnt seem like the sensor is "failing" its getting just slightly lower than ideal readings right? Then again I cant find anything stating where an 06 Z should be as far as PSI goes.
You have the VQ35DE Revup engine. Oil consumption seems to plague that particular model for most (but not all).
As oil engine temperature increases, the oil psi will decrease. You should have higher oil psi at a cold startup as opposed to when the engine is warmed up.
After your engine has reached normal operating temperature (80 degrees celsius), oil psi at idle should be more than 14 psi and more than 43 psi at 2,000 rpms (per the FSM).
I believe that if you run a more viscous oil like 10w-30 or 10w-40, it will flow slower at normal operating temperature and you should see an increase in oil psi.
Guys my oil pressure sensor went bad and my light never came on. My gauge would stay at 0 and 120PSI never got the light. It isn't the sensor. I even replaced my senses with an OEM one and once in a while the oil gauge gets stuck or goes to 0PSI I just slap it and it works again. It isn't the sensor. The oil pressure light has a whole different sensor that works the oil light. Our oil pressure gauges kinda suck anyway
Going to replace the oil pressure sensor next week and will report back if that fixed the problem or not. I think they are like $75 :/ so hopefully it does.
again, it WILL NOT fix your problem. The oil pressure sensor and the oil light sensor are two complete different sensors. Also there have been numerous amounts of memes here that have cracked their upper oil pan installing that sensor. It is super sensitive and you'll have to pull the block which is not worth it. If your oil pressure sensor isn't at 120PSI when the key is on Accessories then it is not broken. Trust me. My sensor went out. Never got the engine oil light. Nonetheless keep us updated
Bmurray350z
03-11-2018 03:37 PM
sentry65
05-20-2005 11:15 AM
y2k3350z
07-06-2003 07:52 PM
