Brake Lights not working. Seeking help
on
Hey guys,
Car ; 2007 350z LED Taillights (brembo conversion )
i just came to a dead end and can’t decide what’s wrong with the issue.
All my lights work. Rear tail lights and headlights. Normally.
I recently came across where when I hit the brakes I don’t see my stop lamps light up. I went as far as
swapping tail lights with someone (nothing)
using my tail lights on my friends car (works fine)
Using his brake switch (worked on his car not mine)
using my brake switch on his car (worked on his car not mine)
checking for shorts in the tail lights and checking grounds.
All fuses are good on all 3.
Replace FULL fuse box behind engine
My question is. Is there a relay or something or what else can I do? Most people have the switch problem but mine seems to be deeper. The only thing I know is that my rotors are warped but that wouldn’t cause my car to not illiminate the stopping lamps as they use too.
on
i know nothing about electrical wiring. I do have a voltmeter from Walmart. A cheap 12 dollar one. Now to check this. I can just stick the voltmeter into the open connector after taking out the headlight connector right? And if there I power and all fuses are fine. What would be next?
cgkp0925
03-02-2016 12:36 PM
Dr.Paulyy
06-08-2014 05:11 PM
nick731
06-12-2012 09:56 AM
