Water in NEW headlights?
hello everyone. My Z came with some aftermarket headlights that had a lot of problems so I went ahead and bought brand new Nissan headlights. New ballast, ballast oring, bulbs etc. I took the car to the car wash once and the passenger side only got a lot of foggy condensation inside. A couple days later my new ballast died bc the hid won’t turn on. It’s an 03 btw and yes I have fenderliners. I got pissed and got a hair dryer and took a bulb out to try it but it came back. I called Nissan and they’re shipping a new one to me very soon with a ballast. When I took the headlight out and checked the ballast it was drenched in water which makes me believe the water got in where the ballast screws on to. How do I prevent this? Was it just bad luck that I got a bad headlight? Or what gives? I sealed everything and installed it all correct. Any ideas guys? Also one thing I think caused it is that my fender liner for some reason doesent completely make a seal with the bumper on the passenger side. Wheel. There is a little opening there. Any ideas how to fix? Again thank you all that took the time to read this. Happy New Years guys! |
Do you have your fender liners in place?
Originally Posted by Bernardo Z33
(Post 10980301)
Originally Posted by KornerCarver
(Post 10980341)
Originally Posted by iideadeyeii
(Post 10980351)
yup
Nope :P
When you seal up the headlight, it's possible to trap a significant amount of water vapor inside the headlight, especially if it is sealed in particularly humid conditions. Part of the way the headlight is sealed is when you install the ballast and bulbs. You can use a vacuum and a hair dryer to dry out the air if you are sure this is the problem.
Originally Posted by Freise
(Post 10980450)
