Catch can to fix blue smoke?
Hey guys so i have a 350z 04, vq35de and i would like to know if deleting the pcv valve by adding a catch can would work to fix the blue smoking?
how severe is the blue smoke?
how many miles on the engine? are you rough on this engine? probably not ... blue smoke is burnt oil - correct? which likely means you have failing piston rings |
Originally Posted by bealljk
(Post 10980697)
how many miles on the engine? are you rough on this engine? probably not ... blue smoke is burnt oil - correct? which likely means you have failing piston rings how severe is the blue smoke? severe when ever i push it how many miles on the engine? around 88k so if i just change my pistons rings it could fix it? |
Originally Posted by kevensavar
(Post 10980698)
how many miles on the engine? around 88k so if i just change my pistons rings it could fix it? The best thing you can do is take it to a mechanic for a formal prognosis and what your options are |
Nope, probably not
(Post 10980684)
(Post 10980698)
how many miles on the engine? around 88k so if i just change my pistons rings it could fix it? The de engines are known for burning oil, but I would find it hard to believe the piston rings are junked at 88k miles, although I don't know the history of the engine. I would get some solid information before writing the engine off/ rebuilding it. |
