Bleeding clutch
2008 350z replaces clutch and slave. Pedal went to the floor I having issues bleeding need help ASAP
There are plenty of posts on how to do it. Try doing a search. Its not exactly rocket science. Or, are you expecting someone to come do it for you? Where's travlee with his "spoonfeed" meme.
Maybe its best you don't bleed the system. Then you can't drift your car into a pole again. |
Originally Posted by Dugan350z
(Post 10994652)
site:my350z.com bleed clutch (or whatever you're looking for) Go and find a post to see how to do it, if you still can't do it or have a weird problem - sure, post it up. |
Quick overview - adjust the pedal for maximum MC stroke before bleeding, then it bleeds like normal. If you don't adjust the pedal, you'll have a very tough time getting it bled with the traditional 2-person method.
Originally Posted by 813_350Z
(Post 10994663)
Maybe its best you don't bleed the system. Then you can't drift your car into a pole again. https://cimg6.ibsrv.net/gimg/my350z....6d88a9c897.jpg |
Just curious; how exactly do you adjust the clutch pedal?
The pedal is typically fixed and has ZERO adjustments. However, the master cylinder fork that connects to the pedal does have an adjustment. Where you referring to that? |
Originally Posted by S0ULJAH
(Post 10995495)
