MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Maintenance & Repair (https://my350z.com/forum/maintenance-and-repair-53/)
-   -   My Driverside Window Won't Roll Down (https://my350z.com/forum/maintenance-and-repair/86019-my-driverside-window-wont-roll-down.html)
jimster716 Aug 2, 2004 08:20 PM
I walk to my car after work and turn on the ignition. As I'm about to leave I roll down the window...or so I thought. The window wouldn't roll down. Grrrr!
Gotta take it to the dealership in the morning and with my mods I don't want to hear any crap about warranty coverage cuz I dare say the window greasing (both windows which I have never taken care of since I don't want the service people to screw anything else up when they open up the door panels) would be a more likely culprit than a rollcage or suspension.
Aarggghhh...the night autocross (once a year event) is this weekend.
They're also going to have to take a look at the fuel gauge since it never goes to full. Yeah yeah, i tried different pumps and topped it off til it was dripping and it still only showed 3/4 full. Getting tired of fill-ups where I only get 8-10 gallons.
My first Nissan. :o
hndumafia Aug 2, 2004 09:07 PM
you're experiencing the faild window motor. since they are going to have to take the door apart anyway you might as well get them to fix the grease streaks.
PoWeRtRiP Aug 3, 2004 06:02 AM
been there done that, make sure they replace the motor in the window and not just realign it
KIKILALA825 Aug 3, 2004 12:49 PM
Mine won't come up!
My z is totally the opposite... i use the keyless entry to roll both window down without start the engine, guess wut ... driver side won't come back up... tried many times with engine on and off...
On my way to the dealer, i give it the last try, and " IT COMES UP!!!" Damn !t..... went to the dealer anywayz... but it works fine, really don't know wut to do about it.:confused:
pimp1911 Aug 3, 2004 02:14 PM
Had driver side done under warranty. Welcome to the club. Looks like this is becoming more common now.
raidersfan Aug 3, 2004 02:21 PM
No kidding, just give the door panel a good smack and it will go up or down. (no way to fix it but if you need it down it works)
raidersfan Aug 3, 2004 02:22 PM
By the way I am on my second motor and this one recently bit the dust.
PoWeRtRiP Aug 4, 2004 05:31 AM
if its stuck in the down position take a pen and pry the window away from the part its stuck against while pulling on the button to make it go up. this will make it unstick and roll up if you really need it to. but it will make some nasty squeal/grinding noises as it goes up. if stuck while up simply manipulate with hand while depressing the button. i lived with this problem for 2 weeks b4 getting it fixed.
chadalac350z Mar 26, 2015 06:10 PM
^^Boss status!! Reppin FL, This s.h.i..t just happened to me too. Wont go down. One week before made nasty noise right before it closed shut on the roll up. then it rolled up and down on its own accord twice. So new motor in the mail to me.
Turbo'ed it last year about 400 hp on race gas. fun to drive. Anyone go to Orlando Speed World in here?
travlee Mar 26, 2015 06:25 PM
holy dead thread revival.... 10.5 years.
Spike100 Mar 26, 2015 06:29 PM
^^ And the window motor is still a problem! :rolleyes:
travlee Mar 26, 2015 06:30 PM
this might be the longest dead one i have seen revived
Spike100 Mar 26, 2015 06:35 PM
Maybe it's the faulty window motor that is the longest running problem in the 350z that just won't die.
The problem is reported frequently over the last eleven years.
deeno Mar 28, 2015 06:25 AM
sheesh! revival ftw!
sucks but good to know others are experiencing it and not just me .
i cleaned the motor last year and was working well... then my pass side went so i did the same.
this year i have to fonzi the window my hitting the door panel as i push the button....
ill replace both motors when its warmer out:suicide::suicide:
Boogshag Apr 1, 2015 08:46 AM
Ive been living with an intermittent drivers side window for a couple months now, but its just now getting warmer so now is when I need it to work the most. Im not convinced that the motor is bad yet since it works occasionally. Also, I think I have gotten it to function when it was stuck down by hitting the door panel with my fist.
Anyone have this issue and able to fix it WITHOUT replacing the motor? Im gonna tear the door panel apart soon and see what I see. Ive already taken it apart about 16x to repeatedly fix a speaker wire...then I replaced the stupid speaker.
travlee Apr 1, 2015 08:48 AM
it is bad, eventually it will stop all together. it has happened to mine and i would say about half the members on here
Boogshag Apr 1, 2015 08:51 AM
Thats the answer I was expecting. Okay, I may as well replace it when I have the door panel off. Thanks for your help
92K1500 Apr 1, 2015 09:22 AM
My windows started getting slower then one day my driver window stuck down. Found if I hit it like you have been doing while holding the switch it would roll up.
Window motors are way too common on the Z's. You CAN open the motor up and clean it out and put it back together but that's just a temp fix. I replaced both motors at the same time and they now roll up and down at the same speed and are much faster.
Boogshag Apr 1, 2015 09:25 AM
Good to know, looks like I might as well just replace it. I think I have a LH motor laying around from the original repair, so I might be in luck!
Tomalam Mar 2, 2017 07:57 PM
Pushed up for 5 seconds
not sure if this works for anyone out there, I had the problem recently where passenger window no longer works. Closing the door it doesn't move up to fill the gap either.
i was about to order a motor when I tried pulling up on the window control, held for 5 seconds, then press down on the window control and it rolled down and started working. Not sure if holding up on it for 5 seconds (like if you were trying to roll window up) reset it or something.
my problem was on passenger side, i held up on the window control from driver side but for the passenger window.
