Attention Nismo V2 Owners With A Drop
i want to get the NISMO suspension i have the NISMO V2 bumper has anyone had problems with the bumper hitting anything, i know the NISMO suspension is only 20mm drop so i think i would be safe js it worth it, i see alot of V2 bumpers with a drop on here just wondering. THANKS:)
The noise of the V2 is longer granted that you WILL scrape, IF you are not mindful of your driving. Other then that the Nismo shock/spring combo will be fine, it's not that much of a drop and your Z will still be managable.
thanks for the info
You'd scrape a V2 even with a stock sus.
Just be careful, alert and know the roads and ramps ur passing. Should be fine. :) |
Just learn how to drive it. I have more drop and TS V1, I dont scrape on the shite AZ passes off as roads... *Knock on wood*
you'll be fine as long as you dont literally run over speedbumps and such. Its not that low but just be cautions.
Same thread, same poster, twice, wee.
https://my350z.com/forum/exterior-and-interior/367995-attention-nismo-v2-owners-with-a-drop.html |
