ahahah you guys are to much... I been doing some small things here and there. Unfortunatly nothing note worthy. I am going to take it out this weekend drive it to see what kinks need to be worked out.
That would be perfection if you didn't have to run quite so much negative camber in the rear. Less stretch, less neg camber, more meat on the tires and it would sit perfect.
If I can't quite afford the Gt3rs I guess this is the next best thing. lol
I totally agree, I am going to have some 18" ccw wheels made for track use, with big sticky rubber.
Originally Posted by litoflow
I am planning on going again by the end of December to Tampa and then Miami. I'll shoot you a pm once im around
Ok I will keep an eye out.
Originally Posted by SlideFox
So what's the next major to-do??
Custom exhaust, alignment, tune, rear diffuser, and few other things.
A few new pics. After taking the heater core out, car has been overheating because the thermostat is not functioning correctly. I am going to make a new hot feed to the thermostat to bypass. So radiator needs to come out to weld a fitting on.
