MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Mid-Atlantic (https://my350z.com/forum/mid-atlantic-331/)
-   -   Hill's Garage and LSD/ gear swap (https://my350z.com/forum/mid-atlantic/524801-hills-garage-and-lsd-gear-swap.html)
Gator May 29, 2011 07:23 AM
Just posted this up in the Engine/drivetrain section https://my350z.com/forum/engine-and-...ml#post9172709. Thought some here might be interested in the performance characteristics of the diff improvements and the job done by Hill's! :icon21:
Neu Era May 29, 2011 07:53 AM
nice! thinking about doing my rear end here soon as well.
denchan350gt May 29, 2011 08:14 AM
What other mods do you have? I saw your car there mine was there having having ES bushings installed front and rear.
I'm thinking about upgrading from my 3.5 to a 3.7 I'm 5at also with the transgo.
Do you have a pic of your dyno sheet? I put down 263hp on hills dyno without cams. Just want to see the difference if I want to install cams or not.
Gator May 29, 2011 09:11 AM
1 Attachment(s)
Engine mods- headers, plenum spacer, K&N Drop in filter, HKS DLI II, C2 cams, UpRev reflash
Tranny- Trans Go shift kit, Cooler, Works Bell paddle shifters
Dyno sheet attached. The day this was done it was super hot and after about 10 pulls, my tranny was starting to slip some a lot. Ambient was like 95 and my transmission was close to 200 if not over. You can see, my best torque was run 1 at about 230 and WHP topped out at 259.4 and run 9.
These cams will give you 10-15 hp for certain. You might also think about the C8 Wolf cams- a little more aggressive but still streetable I think.
vtchang May 29, 2011 10:35 AM
Nice review!
im struggling to drop the diff... :( drive axle 17mm are tough cookies.
Even rented an eco car for the week to have this done.
abui01 May 29, 2011 10:52 AM
diff mods are def worth the cash on this platform, glad you like the new upgrade. Aside from oil coolers, this is one of the mods I'd recommend doing
NNOCENT May 29, 2011 01:27 PM
Hills knows diffs, I was there when Frank pulled apark Mike's for his epic LSD install.
congrats on the new mod!
03threefiftyz May 29, 2011 02:48 PM
^More than once, actually. Aside from race tires.....LSD is the best mod IMO. You'll have to adjust to driving the car. It will push more under partial throttle, etc than it did with the VLSD. I lowered my entry speed ever so slightly and compensated with getting on the power earlier and keeping the entry wide and exit tight.
Gator May 30, 2011 06:05 AM
That makes sense. The first time I got on the throttle the car wanted to push (under steer) but a slight correction took care of that. The solid SPL bushing adds to that effect I think. The rear does NOT move at all. I was mid-corner yesterday and nailed the throttle and shifted from 2nd to 3rd. At full throttle the rear gave a nice hard twitch like it wanted to step out but did not slide when it went into 3rd. That's partly TranGo shift kit too because it shifts very hard. I am anxious to try it at Summit Main this fall.
03threefiftyz May 30, 2011 08:43 AM
I may be there with SCCA as well. As long as I don't have any conflicts.
Gator May 30, 2011 11:56 AM
^ The July PDX is only PDX and is on the Shenandoah circuit. The Last one is time trial and PDX on the main circuit. I will likely work the July one and maybe try to go out as little if I can.
ajcool2 May 31, 2011 12:44 PM
Congrats.
