What 1/4 mile times to expect with a Procharger... Not a question!
So those considering a prochager this is what you can expect... I posted in this area only because this question has come up numerous times here and people want to know what this kit is capable of at the track.
I have a 5AT, Stillen exhaust and the ATI prochager and stock 17 inch wheels/tires. The car dynoed at 368RWHP. Tonight was my first time at the track with this car. Earlier in the week I blew an IC hose so I was not boosting all the way to 7psi. Plus I had to manaully shift at about 4.5 rpm becuase the ATI kit and stock ecu programing for the 5AT don't get along. I made a total of 3 passes. It was about 90 degrees outside and no one was making very good passes. I saw a couple other Z's. One had 75 shot, SES exhaust and injen intake. I never got to see him run but a friend said he was hitting high 13's. My first two runs were 13.41 and 13.44 at 103 mph(zero traction). I was pretty happy. I beat a new CL55 AMG and a new SS camero. My last time I lined up against a modified 2003 ZO6. He beat me, but I laid rubber in 1st and 2nd (again zero traction) and ended up with 13.1 at 105 mph. He had a 12.5 at 116mph. Over all I was very happy. This is easily a low 12 sec car with DR's and 7psi of boost. And will be even faster with a couple other toys. IE cats and plenum. Mods I understand if you want to move this but I know more people visit this part of the forum. I tried to post this as a what to expect with these mods rather than just a 1/4 time thread. |
im dissapointed.. i mean you would expect the mph to increase greatly with that much hp but it stays at 103. Maybe with an ecu modification all will be well.
Thanks for the info nick |
Disappointed?!?:confused: I think its great!:icon4: Did you notice his shift point? 4500rpms, just about where the power starts. Thanks for showing a little sack whosdady!:D I've been wanting to get mine on the track as well but am waiting for some fine tuning. Once we get past this computer thing with the 5AT, mid 12s wont be a problem.:cool: Let's see one of you 6MT Zs get out there.
Speakng of this computer thing, I'm wondering if just an ecu mod/upgrade will be enough for the 5AT. Is there a seperate computer for the tranny? |
The ECU will do the shift points for the tranny so I think that is all we need jetjammer.
103 not good? Did you know that 5AT is short for an automatic? Incase you didn't know, 5AT's never trap very high. On single turbo Supras they were always 6-8 mph slower in trap speeds than 6MT's. However, 5AT's were .2-.3 seconds quicker. 105 is very respectable. Especially for my first time at the track(with this car) ONLY BOOSTING 5PSI (not 7psi), with a 5AT, with stock, thin, all weather tires that spin all the way through 2nd. Like I said earlier this is an easy 12 sec car with any of these issues addressed. |
I know on most other Nissan's, the auto tranny has a seperate control (TMU) to set shift points, etc. I think the Z is the same....
I think it has been mentioned in other post that the issue is not with the tranny, but with the timing being adjusted by the ECU at high RPM's. Not sure if that is correct, but it makes sense. Also, has anybody looked into a valve body upgrade for the auto tranny? This will make for faster shifts, which makes things a little rougher, but it also makes your car faster and causes a lot less wear and tear on the tranny. |
My cousin had this problem with his E55 when he was spraying (250 shot). He had to use a window switch that shut down the Nitrous before the rev limiter or he would just sit there and bang off of it all day. He ran a 12.5 @ 116 mph with it bouncing off of the limiter in 1st gear and 19" Toyo's.
Rougher?
What do you mean by rougher? I have heard this before with my Lexus SC400 but I didn't know what people meant by it.
Originally posted by jran76 I know on most other Nissan's, the auto tranny has a seperate control (TMU) to set shift points, etc. I think the Z is the same.... I think it has been mentioned in other post that the issue is not with the tranny, but with the timing being adjusted by the ECU at high RPM's. Not sure if that is correct, but it makes sense. Also, has anybody looked into a valve body upgrade for the auto tranny? This will make for faster shifts, which makes things a little rougher, but it also makes your car faster and causes a lot less wear and tear on the tranny. |
What it does is increases the pressure of the shift. Are cars with really heavy duty shift kits, they can literally throw you back in the seat on the shift. They are lightning quick, but uncomfortable on a daily driver. usually a mild shift kit is all you would want on the street (enough to chirp on the 2-3 shift! :) )
my friend has a supercharged viper dynoed at 700whp at 4psi can easily take it up to 8 i believe. Anyways yea everytime he shifts i get thrown back even when im expecting it and fighting the throwback
Maybe the Z need like 275 rears to get into the 12's if you were somking the tires all the time....
Originally posted by whosdady 103 not good? Did you know that 5AT is short for an automatic? Incase you didn't know, 5AT's never trap very high. On single turbo Supras they were always 6-8 mph slower in trap speeds than 6MT's. However, 5AT's were .2-.3 seconds quicker. 105 is very respectable. Especially for my first time at the track(with this car) ONLY BOOSTING 5PSI (not 7psi), with a 5AT, with stock, thin, all weather tires that spin all the way through 2nd. Like I said earlier this is an easy 12 sec car with any of these issues addressed. PS, Forget the kick-*** shift kits (mild is much much easier on the tranny) and see whos making a STALL CONVERTER for that thing. That alone will give you nearly 1/2 second in the 1/4, no bs. |
I'm just shocked a 368 rwhp car can only trap 105mph.......somthing is not right. Were you shortshifting ?
Yes, he was in fact...shortshifting..
Yes I short shifted at 4.5RPM. All autos with the ATI under full boost have to short shift until the tranny issues are resolved.
I did speak with JWT today and there is no sure date on the tranny fix (: It looks like it could be a while. As far as the ECU is concerned that shold come out in the near future. After speaking with JWT I learned that we need a separte tranny fix and that the ECU upgrade will not help us shift better. |
Tranny Stuff
I just got a response to my E-mail to Level 10 & they can do a convertor restall & strengthen for $498 plus they offer a $698 valve modification similar to the one Rod Millen does for the Lexus which offers quicker shifts via higher line pressure. In fact, Level 10 advised me that if I supercharge my G35 that I'll NEED these mods sooner or later.:eek: BTW - they just those mods on an FX45 so they have some Infiniti/Nissan tranny experience.
