UTEC's in stock
Just a quick FYI we've got several UTEC's in stock, ready to go for immediate pickup or delivery
Give us a shout if you are looking for one :) Adam |
price and will it work with vortech?
yep will work with any forced induction or NA setup
pricing depends on the exact setup- the UTEC in it's most basic form for a forced induction setup would run you $1079 shipped - that's for a UTEC and the MAP sensor. From there, there are options you can chose to run. One of which is the remote map switch ($75) that allows you to cycle through 5 different UTEC maps that you store at the touch of a button. Second is the wideband tuner, which allows full integration of a wideband 02 sensor into the UTEC, along with some additional datalogging features. Third is the knock light, which gives you real time viewing over knock events without having to have your laptop hooked uo all the time. |
i am looking to up the rev limiter...
would the UTEC do that safely? I have n/a Z btw... |
yes the UTEC allows you to adjust the revlimiter on pre 05 models
I may be in touch with you if Vortech does not warranty my Split Second box.
bump bump bump!
Also, all Unorthodox Pullies are on sale! Invidia Exhausts, ACT Clutches and more!! SPC rear camber/toe kits also in stock for $200 picked up!!! One set of Power Enterprise 510cc injectors on BLOW OUT SPECIAL!!! We are now your Tri State Source for Altered Atmosphere products!! Fuel rails, exhausts, plenum spacers - let us know what you need and we'll be happy to help Adam |
| All times are GMT -8. The time now is 01:14 PM. |
