Oil cooler/warmer removal.............
Old 02-06-2008, 05:29 AM
QuadCam
QuadCam's Avatar
Default Oil cooler/warmer removal.............
Here's a pic of the oil wamer/cooler from the service manual. I will be eliminating this deviceand it's associated plumbing from my engine. So, please don't debate over its usefulness or non-usefulness!
My question is what do I do with the stock "connector bolt" and also the "relief valve?"
Can the stock "connector bolt" be cut down and rethreaded? or does anyone know of a shorter bolt that fits these engines. I'm not even sure of the thread size. Unfortunately, I have 3 VQ35 engines and the only one with the bolt is the engine in my car. I'd like to figure everything out before I tear it the project on my car.
Secondly, what are the "relief valve?" Do I need to do anything with it? will it still work if I only have a filter screwed onto the block?
Thanks for any insight!!!
Andrew
Old 02-06-2008, 12:32 PM
MardiGrasMax
MardiGrasMax's Avatar
Get the connector bolt from a VQ30. I cant remember what to do with the relief, sorry.
Old 02-06-2008, 01:00 PM
QuadCam
QuadCam's Avatar
that's an idea. BTW, what cars came with the vq30?
Old 02-06-2008, 01:09 PM
kevinapex
kevinapex's Avatar
the thread of the stem is 1.5M
Here are a few picts. I don't see the by-pass?
Old 02-06-2008, 02:37 PM
phunk
CJ Motorsports
phunk's Avatar
i just replace the entire thing with a MOCAL thermostatic oil cooler sandwich. In order to do so, we had to lathe a small sleeve to adapt the Mocal to mimick the cooler. Now my oil filter threads right onto the stock bolt and the mocal thing. its nice, got rid of the extra water lines for that thing too.
Old 02-06-2008, 02:45 PM
kevinapex
kevinapex's Avatar
That hard pipe is kinda a beehutch to remove.
Old 02-06-2008, 02:46 PM
MardiGrasMax
95-99 Maxima's had VQ30s
Old 02-06-2008, 02:49 PM
Dave 90TT
350Z 2+2
Dave 90TT's Avatar
I won't debate it with you, and won't counter your reason, but I am interested in your reason for removing it.
Old 02-06-2008, 02:55 PM
phunk
CJ Motorsports
phunk's Avatar
they are just bad news for highly modified cars. many engine builders will tell you to just replace that cooler every time you build your engine because it gets so clogged up with debris and they are impossible to totaly clean.
Advantages to removing it:
Cleans up engine bay a lot
Gives you a clean place to put an external cooler sandwich
no worries about it containing debris
disadvantages to removing it:
zero
My car warms up just a fast. My oil temps are only better with the front mounted cooler (which is behind my intercooler)
Old 02-06-2008, 02:57 PM
QuadCam
QuadCam's Avatar
to get rid of crap on the car! I am also removing alot of the nipples on the water and heater pipes. There are so many small water hoses running all over the place. To me, those are just potential place for lines to burst and lines.
Old 02-06-2008, 03:04 PM
QuadCam
QuadCam's Avatar
Charles,
any pics of that sleeve you machined? any chance of machining another one?
Damn, I wish I had all the machine shop tools you have access to!
Old 02-06-2008, 03:11 PM
Dave 90TT
350Z 2+2
Dave 90TT's Avatar
zero
Ok, thanks for the reasons.
Old 02-06-2008, 03:36 PM
Drewer
Drewer's Avatar
Sorry for going slightly off topic, but since you're already doing it I thought I'd ask:
When I get my sandwich plate for my oil cooler, will it completely replace that "warmer/cooler" stuff you took out?
Hmmmmmm. . .so much to plan for! So much stuff to install! So little time!
Old 02-06-2008, 03:44 PM
Dave 90TT
350Z 2+2
Dave 90TT's Avatar
It can.
You can also keep the warmer/cooler on. I have two sandwich plates (one Greddy for temp and pressure sensors, and one Mocal thermostat plate for my oil cooler), and the stock warmer/cooler. Clearance is a bit tight when changing the oil filter, but still possible.
Old 02-06-2008, 03:54 PM
Drewer
Drewer's Avatar
It can.
Mmmkay, thanks Dave. Last question before I kick myself for threadjacking:
LOL This one is a "outline" question:
I. For an oil pressure sensor, doesn't it need to be inline with the oil sender, ie with a pressure source?
......A. aka why use the second sandwich plate for the pressure?
...............1. also, can't you get the oil temp buy using a spacer?
Reason I ask is I plan on getting both sensors, but already have a tapped oil pan spacer which I plan to use for the temp sensor, but am still investigating where to run the pressure sensor from. Thanks!
Sorry for the threadjack, QuadCam!
Old 02-06-2008, 05:31 PM
QuadCam
QuadCam's Avatar
Damn you threadjackers!!!!
Old 02-06-2008, 05:55 PM
MADScientist
MADScientist's Avatar
I just threaded the rest of the connector bolt and then cut it to size, removing the nut portion. Then I used an Earls sandwich adapter and used lock tite to link the connector bolt and the Earls bolt together making one long treaded piece with a sleeve in the middle to locate the sandwich plate...
Sorry no pictures, but it was pretty easy to do, had to special order a die that big to thread the bolt however...
Good Luck!
Old 02-06-2008, 06:46 PM
QuadCam
QuadCam's Avatar
jkenefic,
do you recall the correct die size?
Old 02-06-2008, 07:52 PM
MADScientist
20x1.5
Old 02-07-2008, 09:09 AM
QuadCam
QuadCam's Avatar
I took my coolant and heater pipes to an experienced welder (17 yrs experience) to have him grind off and weld up the holes left by all the nipples I removed. I also had him weld up -8AN fittings for the radiator bypass hose.
The problem came from the heater and coolant pipes (the gold pipes on either side of the block). He's not sure what typeof alloy those pipes are made from, and whether he tried MIG or TIG welded on those pipes, there was some wierd off-gassing that was causing "porosity" in the welds.
Does anyone have any tips in regards to welding on those gold pipes? anyone know what nissan di to those pipes? I have heard of others having issues with welding on these pipes in the past, but I just assumed it was due to an inexperienced welder.
Quick Reply: Oil cooler/warmer removal.............
