350Z In LIMB. P2122, p2138
Hello Guys.
I hope you can help me out.
My Z'ed keep's giving me a hard time.. Im getting error code P2122, P2138 all the time and the car goes into LIMB mode
I had my OBD reader on it several times to clear the code without any luck..
P2122 Accelerator Pedal position Sensor
P2138 Accelerator Pedal position Sensor
I have changed the accelerator pedal sensor, and i've also changed the plug going to it since the previous owner had given it a hard time.
I also tried tweaking the connectors on the throttle body a little to give it better connection without any luck?
Anybody has an ide on what this could be? Should i replace the throttle body or is it something else? Sometimes i can get it startet without having the error code but i can start in 30sek og 30min later.. In that time the car works Perfect!
I cannot be the only guy experiencing this
Same codes
Both codes plus sec light vdc off and slip light. Erase with scanner but come on immediately after starting. Replaced pedal sensor throttle body checked all connections
liqalu04
01-02-2022 12:58 PM
