TOMEI 2 way lsd installation problems
Old 11-24-2013, 10:50 AM
Mrbobfisher
Mrbobfisher's Avatar
Talking TOMEI 2 way lsd installation problems
Hey guys I have a 2003 Nissan 350z, enthusiast model. this car should have VLSD on it as long as the original owner didin't swap it out before. so I bought a TOMEI 2 way aftermarket differential and I attempted to install it myself. I got the differential installed and it seems to spin the gears fine, the problem is my side flanges will not go in all the way. The shorter flange went in perfectly but the longer one that goes in closer to the ring gear loosely drops in but doesn't lock in all the way and pulls out with barely any effort. I tried switching them and then they both will not go in all the way. I bought the TOMEI on ebay listing said TOMEI Nissan 350Z Z33 2 Way LSD Drift Differential VQ35 # 562020 http://www.ebay.com/itm/171029862979. It said in the listing for VLSD didint say the year but I messaged them they said it would work for my 03 with vlsd. Any help would be really appreciated
Old 11-24-2013, 10:54 AM
Mrbobfisher
one more picture of the pumpkin
Old 11-25-2013, 07:19 AM
You need to provide useful pics
Old 07-14-2014, 06:21 AM
pfregeolle
pfregeolle's Avatar
Just curious if you ever got this sorted out?
Old 07-15-2014, 12:42 AM
MonkeyMagic72
MonkeyMagic72's Avatar
There should be a c-lip to lock both the short and long stub/flange side axles inside. You should try to look inside the Tomei LSD to see if there are any c-clip inside to lock it in. If not, try to look in the OEM VSLD to see if the c-clip is in there, and you can take that one out and use it to install on the Tomei LSD to lock the side flange axle in. The c-clip should look like the item part number 38255+A in the picture below.
Old 07-15-2014, 04:16 AM
pfregeolle
pfregeolle's Avatar
^ That's kind of what I was thinking too, I was hoping by now he was able to figure it out haha
Correct me if I'm wrong, but isn't there only a CirClip on the driver's side stub (the longer one that only VLSD's came with)?
Old 07-15-2014, 11:03 AM
MonkeyMagic72
Thumbs up
You are correct about the the longer stub axle is the only one that has C-clip. It can easily confirmed in the picture bellow that only the long stub axle has the C-clip, and the short one does not has it. I also remember when I had my Tomei SLD installed, the C-clip fell out, and then I have to pick up from the ground and used a rag to clean it. Then I put the clip on the stub axle and carefully slide it in the side of the diff to snap and lock it in.
Here are four different images take directly from Courtesy Nissan website with different 350Z year model that included VSLD and open differential are worth to look at.
Old 07-15-2014, 01:27 PM
guitman32
guitman32's Avatar
There is a circlip used for both axles in every diagram you posted.
Old 07-15-2014, 02:50 PM
MonkeyMagic72
Yeap, the small print part number 38225 and 38225+A left and right c-clip got me there. Now, I wonder how I got that c-clip on the short stub axle when I installed the LSD. So, the lesson is, always have factory manual in front with diagram when install parts.
Old 01-21-2019, 07:54 PM
Sirdabs
Sirdabs's Avatar
I’m having this same problem just want to make sure that I’m reading this right there is supposed to be a c clip on both short and long side stub shafts !
Old 01-21-2019, 07:59 PM
pfregeolle
pfregeolle's Avatar
There should be a c clip only on the long stub
Old 01-22-2019, 06:31 AM
Sirdabs
Sirdabs's Avatar
Ok well there was one on the short side but not the long and the short one stays in but the long one has play !!!
Old 01-22-2019, 09:09 AM
guitman32
guitman32's Avatar
If you dont see it on the axle it may have stayed in the diff...you can see it if you look inside.
Old 01-22-2019, 10:07 AM
Sirdabs
Sirdabs's Avatar
Ok I found it thank u but now it’s in and I’m still having the issue . .. the shaft should stay all the way in no play correct for some reason I have play on the right and it pops out easy so when i put it on the ground and started turning I can here it piping out an in this my daily and I’ve been down for 3 days now man I need this fixed lol
Old 01-22-2019, 03:23 PM
guitman32
guitman32's Avatar
There is usually slight play in the stuub axles, yes. The circlip may be worn out or bent out of shape if youve actually verified that its popping out of place.
XM 1
07-10-2022 07:44 AM
Uriyo_
09-08-2021 08:46 AM
Lt_Ballzacki
08-06-2021 06:19 AM
Quick Reply: TOMEI 2 way lsd installation problems
