Engine Stalls if not given a little gas on startup
Old 09-24-2015, 10:40 PM
liqalu04
liqalu04's Avatar
Unhappy Engine Stalls if not given a little gas on startup
Hey guys, I just bought a 2004 350z Touring 6mt. I am not new to 350z's, I've owned one before and never had this problem. Every time I start the car, then engine immediately idles really low, and dies off. If I give it a little gas for a few seconds, it then evens out and idles at around 600.
Does anyone know what this problem could be? The previous owner told me it has been doing that for the past year or so.. I don't know why he didn't have it looked at or try to figure out the problem.
I was thinking it could be a dirty MAF sensor or something along those lines, but I'm not really sure. Any advice would be greatly appreciated!
Thanks
Old 09-25-2015, 10:57 AM
jdm-v35
jdm-v35's Avatar
try cleaning the MAF and idle air relearn.
Old 09-25-2015, 11:22 AM
Heel Til I Die
Heel Til I Die's Avatar
for MAF.
Do you have an aftermarket air filter?
Old 09-25-2015, 12:30 PM
http://lmgtfy.com/?q=Engine+Stalls+i...e%3Amy350z.com
VenomGT9 (09-26-2015)
Old 09-25-2015, 02:35 PM
liqalu04
liqalu04's Avatar
I do not have an aftermarket intake or filter, I'm not sure what brand the actual filter itself is. It's just a red and white paper filter, might try to change it out even though it's not too dirty.
I already googled this, and found people with similar problems, but no one's exactly like mine. Mine seems to be unique because it's only on startup that it needs a little extra gas, after that it runs fine the whole time I drive it.
As far as the MAF sensor, I will try to just clean it, if that fails would replacing it be the best option?
Old 09-25-2015, 02:44 PM
reset the ecu, idle air relearn, throttle position relearn.
Beniben (01-31-2022)
Old 09-25-2015, 03:39 PM
PP08HR
PP08HR's Avatar
I'm gonna go with a throttle body service, disconnect battery for a few minutes to reset ecu.
Please report back.
Old 09-26-2015, 10:01 AM
VenomGT9
VenomGT9's Avatar
This is the future
Old 09-26-2015, 12:46 PM
Idle relearn/throttle body relearn, I have the same problem every time I disconnect my battery.
Old 09-27-2015, 08:48 PM
nachospizza
nachospizza's Avatar
This happened to me couple years ago!!! End up was a going to died fuel pump causing this problem!!! So replaced a brand new unit and no more idle low and died down sympthom. Hope this helps!
Old 09-28-2015, 03:09 AM
start with the possible free fixes listed here before throwing money at it
Old 02-16-2017, 05:39 AM
abudy05
abudy05's Avatar
Default Problem with throttle body, any mechanics?
Hey guys, I'm having a really bad issue with my throttle body. My idle keeps surging or hunting between 1.5 and two RPMs at all times. I took it to Nissan, they said they couldn't read anything on the computer because it's been auto tuned. I'm about to move back to America and I'd like to sell my car. It's a 2007 350z, Canadian specs. I just changed the MAF sensors and fixed my dual exhaust. It's got some mods like Cold Dual Air Intake. My question is, can anyone recommend a good mechanic to fix my throttle issue? Thanks!
Old 02-24-2017, 08:38 PM
350z54
350z54's Avatar
Default throttle
Thanks
I had this problem in my 2003 g35 coupe I cleaned the throttle body with some throttle body cleaner I pushed the little thing back that people say don't push back an cleaned the edges an than it worked fine cranked perfect I'm 80% sure this is your problem
Old 04-05-2017, 04:43 AM
aqe040466
aqe040466's Avatar
Thanks
Check the Idle Air Control Valve, try cleaning it, if it won't fix, buy a new one.
Old 04-05-2017, 04:54 AM
or... hard concept, take it to nissan for a diagnosis.
Old 10-20-2017, 08:42 PM
Vaginator
Vaginator's Avatar
I don't know if you get this... hard concept, but he may be trying to do this himself and save money like 99% of the people on this page
Old 10-21-2017, 03:43 AM
6 months late to the party doucheinater
Atreyu'z 350 (10-22-2017)
Old 10-24-2017, 10:28 AM
CK_32
CK_32's Avatar
I was told there was a party?
Sorry I'm late. Hit traffic. What I miss?
Theminatar (10-24-2017)
Old 10-24-2017, 11:54 AM
Atreyu'z 350
Atreyu'z 350's Avatar
Oh nothing much.. Just Travlee calling Vaginator a doucheinator for being a Travlee hater.
Old 10-24-2017, 12:09 PM
i mean diagnostics are usually $125 tops and then you know what is wrong with it, no guessing. hell i am about to do it on my corvette, just to make sure that i am right....
Quick Reply: Engine Stalls if not given a little gas on startup
